Results 1 to 2 of 2
Thread: Dyno chart VF115 Yamaha SHO 115
09-22-2018, 07:53 AM #15000 RPM
- Dec 2005
- Valrico Fl.
- 564
I have been looking for a dyno chart on the Yamaha SHO 115 /VF115 . They have a max RPM at 6300 as per Yamaha .They rated the 115 HP at 5500 RPM but factory max RPM is 6300 seems like if it is rated at 5500 and redline is 6300 either they make more than 115 HP at 6300 or there is no need to twist it pass 5500 if that’s where it’s making max HP . A dyno sheet sure would help. I have asked both hydra Tech and Dave Busch Racing about dyno sheets seems like if a company is reflashing there ECU they would have set up the motor on a dyno to see if the reflash had performance gains . Wondering at what RPM max HP was made and how aggressive the power range is . I was hoping that someone has had one of these on a dyno and could share . A few years ago when I was running a F 150 one on the members had a copy of the F150 dyno numbers . The F150 made max hp about 300 RPM less than everyone was saying and was very helpful . Lots of comparisons between the Merc 115 4 stroke and Yamaha but no dyno records posted that I have been able to find . Thanks for any help. Joe R
09-26-2018, 08:19 PM #2Team Member
- Lake Coochiching, Ontario
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
HP = torque X rpm / 5252
It's normal for torque to drop off at higher rpm so it's quite possible that the engine makes less HP at 6300 than at 5500
None of the motor companies routinely publish the torque and horsepower curves, with is too bad.
Power curve or dyno chart SHO 115
By Dingie 2 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 05-16-2017, 09:47 AM -
Whats are the dyno numbers Yamaha F 150 @ 6000 RPM
By Dingie 2 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 8Last Post: 08-22-2012, 03:49 PM -
OMC Jet Chart?
By badgpz in forum Technical DiscussionReplies: 1Last Post: 01-30-2002, 03:21 PM
