Results 1 to 3 of 3
09-20-2018, 09:24 PM #1New Member
- Sep 2018
- California
2.4L Racing Merc shut down problems
Hello everyone. I have a 2.4L BP. Still fairly new to me. I'm having trouble with the engine shutting down completely at times. I had already replaced two injectors which were bad. Also replaced the two switch boxes, the trigger, one coil, new spark plug wires and plugs. Checked the fuel pressure on the fuel rail and had 39psi. I was running real good the other day. Did a couple runs about 10min long a piece full throttle ran good. Sat for a while, started up, took off ran for about 2min then just completely died. This happens often. When it does die I have to wait about 5min before it will start back up. When It starts back up sounds at first like its starving for fuel then runs good. Got me back in at least. Fuel pump does make a little bit of noise but still has 39psi. Any help on this would be appreciated.
09-23-2018, 08:11 AM #2
Ingintion switch,or kill wire could be a problem.Take a spare plug with you,when it dies take a plug wire off,plug it on your spare plug and see if you've got spark.Seems like some of the older ECMs would lose a driver and shut down.
09-24-2018, 07:44 PM #3New Member
- Sep 2018
- California
Thanks. I will try that if it happens again. Went out yesterday and It didn't die on me. The only things I've done different was relocate the fuel return line so it wasn't returning right over the suction tube and replaced the rectifier.
200hp Carbie Merc will not shut down
By savage boat in forum Technical DiscussionReplies: 2Last Post: 11-01-2009, 05:59 PM -
Intermittent Shut Down 2.5 EFI OS Racing Powerhead
By Sharkey-Images in forum Technical DiscussionReplies: 11Last Post: 08-12-2005, 09:58 PM -
merc 2.5 OS race shut off
By tmr4479 in forum Technical DiscussionReplies: 1Last Post: 05-15-2005, 07:32 PM -
The answer to O/B Drag Boat racing problems...
By T-REX in forum General Boating DiscussionReplies: 10Last Post: 06-12-2001, 08:07 PM
