Results 1 to 4 of 4
Thread: EFI 250 from a 300X
09-18-2018, 11:43 AM #15000 RPM
- Apr 2005
- 144
EFI 250 from a 300X
The 300X died again. Block has a hole on the side (again), needs a crank and sleeve. I would like to build a simple and reliable fishing motor. Will the 250 EFI power head bolt to the 300X midsection? How much of the hardware will I be able to reuse? Ignition coil, flywheel, oil injection pump, alternator, fuel injector, starter cowling, ECM, VST, linkages, ect. What will I need to buy? Is it doable or not worth it? My 300X is very clean with the parts that rusted have been ceramic coated. I think the 300X is the best looking OB and want to keep that look.
09-18-2018, 01:26 PM #2
Yes , you can use every bit of your existing bolt on components . Just replacing your basic shortblock and heads for a lower compression 250 EFI .
It's kind of like doing what we are talking about in the 225/250 thread ... but in reverse ..
09-18-2018, 03:17 PM #35000 RPM
- Apr 2005
- 144
Hi Chaz. How about the ECM? How will the motor run with a 250 efi power head and a 300X ECM?
09-18-2018, 04:23 PM #4
Same as all the other 250's that had their box reflashed ..
New 15” 300x mid
By lift2win in forum Misc. Parts and AccessoriesReplies: 0Last Post: 02-17-2018, 11:20 AM -
wtb 300x skirt, Imco plate and two tilt pins for 3,0L 300x/promax
By pdub in forum Misc. Parts and AccessoriesReplies: 0Last Post: 03-11-2017, 10:55 AM -
260 to 300x
By rottenbottom in forum Technical DiscussionReplies: 2Last Post: 01-24-2006, 09:42 AM -
xb-21+300X=What?
By lxbud in forum Props, Setup, and RiggingReplies: 2Last Post: 02-17-2004, 11:48 AM
