Results 1 to 4 of 4
09-18-2018, 12:04 AM #1
Need Connecting Rod Bearing Help Mercury 2.0 Fat Block
Guys, I want to find me some steel caged connecting rod bearing "sets". I don't want the nylon/plastic cages that came off the crank.
Can one of you give me the part number for the steel caged bearings. please? The parts fiche only shows me the plastic ones available for the 1996 block. See below -
Thanks, Gordon
09-18-2018, 04:47 AM #2
Go to pro marine website. very easy to find parts you need
09-18-2018, 05:03 AM #3
http://parts.promarineusa.com/CGI-BI...65908L+M50+ENG
The 514 from pro-marine is metal caged, the 514R is the race version, also metal caged for a lot mo money, better material for higher hosspower and rpm.
09-18-2018, 04:32 PM #4
Guys, thanks for the info. These are cheaper that the factory nylon bearings too.
$40 per rod for the set....the stock ones are almost $50.
Gordon
1995 mercury 2.5 260 big bearing block
By superboattwin250 in forum Misc. Parts and AccessoriesReplies: 3Last Post: 04-15-2018, 04:57 PM -
Mercury 260 Big Bearing Block and matching front half.
By Ace in forum Misc. Parts and AccessoriesReplies: 2Last Post: 06-18-2017, 01:32 PM -
Mercury Big Bearing 260 block
By tgreen in forum Misc. Parts and AccessoriesReplies: 3Last Post: 05-03-2017, 10:11 PM -
280 connecting Rod Bearing set of 6 New in box
By raymo1979 in forum Misc. Parts and AccessoriesReplies: 0Last Post: 06-08-2014, 03:13 PM -
Connecting rod bearing failure on a 1991 90hp Merc
By Boz in forum Technical DiscussionReplies: 15Last Post: 10-13-2003, 04:36 AM
