Results 1 to 4 of 4
Thread: Mercury 2004 EFI 225
09-17-2018, 08:11 PM #15000 RPM
- May 2017
- US / NC
- 131
What the best way to remove a break port check valve at the bottom (front half ) of the block . Kind got away from me and hit the wall . Was clean up the parts.
The block is split and on the bench .If that will help . Back yard tech , learning the hard way .
Thx
09-18-2018, 05:56 PM #2
can you be clearer about what you're doing? Maybe use a pic or two?
09-19-2018, 05:48 PM #3
I think he means he was cleaning it and hit bleed/check valve and broke it off??
09-28-2018, 09:44 PM #45000 RPM
- May 2017
- US / NC
- 131
By RiChavis in forum Technical DiscussionReplies: 0Last Post: 09-14-2018, 01:13 PM -
2004 mercury 250 EFI
By jfm in forum Technical DiscussionReplies: 14Last Post: 02-28-2011, 08:37 PM -
By jfm in forum Props, Setup, and RiggingReplies: 7Last Post: 09-25-2010, 03:01 PM
