Results 1 to 9 of 9
Thread: 89 200 xri
09-13-2018, 10:56 PM #1
New Member
- Mar 2004
89 200 xri
The voltage on my tps checks backwards.7.46 volts at idle and 2.40 volts at wide open throttle. Any ideas greatly appreciated.
09-14-2018, 02:54 PM #2
Are you using the Merc tool?
09-14-2018, 04:13 PM #3
New Member
- Mar 2004
No.Just using a multimeter and probing the blue and orange wires.
09-14-2018, 07:02 PM #4
5000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 411
- 53
- 12
- 106
- 47
IDLE voltage should be .135-.150 7.46 wot disconnect temp sender on port head 2 brn leads turn unit all the way clockwise then back slowly. just did mine 2 days ago
09-14-2018, 07:19 PM #5
New Member
- Mar 2004
Temp sensor has been unhooked and it checks 7.46 at idle no matter where you set the tps. It only changes when you move towards wide open throttle then it drops to what it should be at idle.
09-18-2018, 05:53 PM #6
I'd say you have the wrong wires probed, I've seen a manual that said to probe the wrong colours...try different combinations, I forget which but you'll work it out after a few attempts
09-18-2018, 06:48 PM #7
09-18-2018, 07:01 PM #8
09-18-2018, 08:50 PM #9
Made three little brass pins. Works great.
RockTeam Junk
