Results 1 to 9 of 9
Thread: 89 200 xri
    Mar 2004
    89 200 xri
    The voltage on my tps checks backwards.7.46 volts at idle and 2.40 volts at wide open throttle. Any ideas greatly appreciated.
    Are you using the Merc tool?
    Mar 2004
    No.Just using a multimeter and probing the blue and orange wires.
    Feb 2011
    HUDSON, FLORIDA
    IDLE voltage should be .135-.150 7.46 wot disconnect temp sender on port head 2 brn leads turn unit all the way clockwise then back slowly. just did mine 2 days ago
    Mar 2004
    Temp sensor has been unhooked and it checks 7.46 at idle no matter where you set the tps. It only changes when you move towards wide open throttle then it drops to what it should be at idle.
    Jan 2010
    Rotorua, NZ
    I'd say you have the wrong wires probed, I've seen a manual that said to probe the wrong colours...try different combinations, I forget which but you'll work it out after a few attempts
    Quote Originally Posted by gmacrae View Post
    Or buy the tool and stop poking holes in insulated, sealed wires.
    Jan 2010
    Rotorua, NZ
    Quote Originally Posted by Dave Strong View Post
    the harness on mine isn't sealed (ECU side)...but ya can always run a single strand of wire around each connection inside the plug and re-plug it I guess if you don't wanna mess with a harness that is sealed
    Pekin, IL
    Made three little brass pins. Works great.
    Rock
    Team Junk
