Results 16 to 30 of 43
Thread: RIP You sumbitch
09-07-2018, 10:38 PM #16
09-08-2018, 07:41 AM #17Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
09-08-2018, 07:51 AM #18
Watched a special last night on Burt and Hal Needham (Burt's stunt double). Very good. Two impressive movie makers gone now.
RockTeam Junk
09-08-2018, 04:14 PM #19The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...Never heard of the term pigment separation in my lifetime of resin/gelcoat use. The South Florida sun is one of the most brutal on gelcoats/resins/laminates, and even worst on any dark pigmented gelcoat, which is why you simply stay away from them, on decks especially. But like any colored gelcoat boat, you gotta take care of it. Its like the upholstery in boats. Everyone thinks, well...It's "marine upholstery"...you can leave it out in the sun, wash it down with the hose all the time, and it will last cause its "marine" & it can take it. Not true. By the way, I neglected to mention in my above Burt Reynolds new boat build story, that Burts lifelong nickname was "Buddy".
09-08-2018, 07:21 PM #20Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
09-09-2018, 10:29 AM #21
09-09-2018, 10:34 AM #22
I always admired Burt's career, one of the most successful of our lifetime. belive he had a streak of doing at least one film a year for decades. He and Clint probably will go down as my favorites. RIP Buddy, fun out
most overnite successes usually take at least 10 years
Certified turd polisher,
NICE PAIR liked this post
09-09-2018, 02:13 PM #23
09-09-2018, 09:12 PM #24
goin to miss this guy, one of my all time favorites, sad to see him go
09-09-2018, 11:36 PM #25
09-09-2018, 11:38 PM #26
09-09-2018, 11:51 PM #27Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
09-12-2018, 05:35 PM #28The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
Any dark or darker gelcoat color will have much faster oxidation/fade issues when left to bake in the sun. This is why 99% of manufacturers don't build with any dark gel. They build mostly white gel boats. Then they apply paint. Also staying away from dark paints too, if possible. All resins and gelcoats(which are simply pigmented resins) have what they call a "Heat Distortion Temperature Rating". This specific temperature is the temperature at which a cured resin or gelcoat will begin to "move", or distort, or what we call "post-curing". Depending on the resin base that a particular gelcoat starts with, before colorizing, these temperatures vary, depending on the rating, or quality of resin. Better resins/gels, have higher ratings. General purpose resin has the lowest generally. Vinyesters & other blends higher, and so on. Temperature ratings can vary on one particular resin/gel due to other factors, such as cure rate/time, ambient temperature when used, catalyst type & speed & amount, etc., for the finished part/product. Many other variables come into play. This is why there are laminating resins/gelcoats...and tooling resins/gelcoats. Prices vary wildly, depending on product. Ever look down the hullside of an older dark colored offshore boat, and see the woven roving print-through, telegraphing through the post-cured lamination?
NICE PAIR thanked for this postNICE PAIR, powerabout liked this post
09-12-2018, 06:50 PM #29The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
A dark colored gelcoat, that is typically rated at say, 125 degree's, starts moving at 126 degree's, when sitting in the sun. A temperature attainable with any dark gel(or dark paint on top of gel), and far beyond. A white gel, not so much. All of the colors from a particular gelcoat venders line, utilize the same resin base. So using any of they're available whites or lighter colors, and you should never have an issue. There are many different gelcoat grades/pricing. A Corvette hood, for example, is manufactured with a much higher Heat Distortion Temperature Rated resin. Food for thought.
09-12-2018, 08:02 PM #30Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
are you saying oxidization can be buffed out or permanent change in the gelcoat?
Bad ones I have seen the gelcoat has changed and has spots in it.
