Results 1 to 2 of 2
09-05-2018, 05:52 PM #1Member
- Jan 2007
- 49
- 7
buying a used 300xs run in the salt...plus octane question
So I'm looking at a boat with a 08' 300xs, under 250 hours, that has been run in the salt.
- Always a good sign if engine looks clean visually...but what else to to check for corrosions issues? (other than standard stuff... compression check, read plugs, examine gear oil, etc)
- Fuel injectors and Air injectors were cleaned last season...Anyway to verify Air Pump condition, other than listen?
- FWIW Haven't bought a salt run outboard in a while....last one had a hole in the water jacket I only found after 50 hours of run time, so not sure what options I have, other than pulling a head? (probably wouldn't go over well with the seller)
- When you are stuck at a Marina with regular gas only, is there an octane booster suggested for the 300xs? Or just asking for trouble on anything less than premium at the pump?
Thanks!Last edited by motuman; 09-05-2018 at 06:03 PM.
09-10-2018, 01:20 PM #27000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
use race gas. by that i mean a consentrated[sp] bottle that is added to gas at a ratio, and not ra e car gas or airplane fuel.
go to racegas.com
Questions aqbout buying 300xs from jacos
By LOSTINJ in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 25Last Post: 04-24-2018, 09:34 PM -
300Xs Salt Pan Faicilty.
By Bjorn08 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 2Last Post: 04-17-2015, 08:58 AM -
300XS octane: DANG IT! Put in a half tank of 89 Octane! Thanks, Marina!!
By Philster in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 7Last Post: 05-29-2012, 05:24 PM -
Mercury Tech: 300XS - any way to run regular 87 octane?
By JoshF in forum Technical DiscussionReplies: 13Last Post: 04-25-2010, 06:43 PM -
Salt vs Fresh merc 300x or 300xs
By chris1978 in forum General Boating DiscussionReplies: 5Last Post: 11-28-2007, 08:25 AM
