Results 1 to 10 of 10
Thread: 300 xs alarm
    Nov 2013
    Wakefield, NH
    300 xs alarm
    hey all, could use a little help. went out for a ride, motor semmed to be running a little rough, try to plane off, it wouldn't spin up. out of gear, rev it up in high idle, alarm comes on right away 1500rpm????? any ideas
    Jan 2016
    If it is a racing opti 300XS, you're not supposed to rev in high idle. The TPS "learns" last idle position and will throw a code. As far as rough, need more info but fuel lines, maintenance, pulse pump, sticking thermostat come to mind as potential culprit(s).
    Joe Perez
    00 Triton TR21/14 Mercury 300XS Level 1.1 DBR Kit
    Check to see if you lost a coil...Or a coil wire is loose or bad. Just went thru this with my opti.
    Aug 2018
    MI
    Nov 2013
    Wakefield, NH
    Quote Originally Posted by moatorbotin View Post
    thanks for all the feedback, i was kinda thinking coil, it seemed to b running rough like i lost a cylinder or two. went out day before, all was good, do these things just go like that?
    I have had my opti lose a coil and not make a beep. Just ran poorly. I just had a plug wire get a bad spot on it (lost that cyl) and it beeped like crazy. Beep chart helps, but is not the bible IMO. If you have a timing light, hook it up on each plug wire and run the motor and check with light. No flash no fire, shut down the motor to move to another wire. You can get a bad shock from them if not careful.
    Nov 2013
    Wakefield, NH
    ill check that, thanks
    Western Pennsylvania
    I have 3 300xs coils listed for sale at $75 each if interested?
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    Nov 2013
    Wakefield, NH
    Quote Originally Posted by Euroski View Post
    well after checking everything i could, i caved to bring it down to the local dealer, put it up on computer. to my amazement, everything checked out fine????? he said maybe battery not putting out enough power, what, but it starts and runs???? new battery, all is good, just never know, sometimes its so simple! thanks all for the input.
    Apr 2017
    Pomona ny
    Opti's can't be revved out of gear that was the cause of the alarm.
  1. oil alarm ????????
    By mragu in forum Technical Discussion
    Last Post: 06-12-2015, 08:53 PM
  2. Alarm
    By 4fiddyR in forum Technical Discussion
    Last Post: 06-09-2012, 10:34 AM
  3. 300 pro max alarm
    By skaterjim in forum Technical Discussion
    Last Post: 05-07-2010, 05:26 AM
  4. Mercury Tech: Oil Alarm ... WHY??
    By WOT RACING in forum Technical Discussion
    Last Post: 06-28-2009, 10:27 AM
  5. Alarm is going off! HELP!
    By Glasply150 in forum Technical Discussion
    Last Post: 08-04-2005, 03:26 PM
