Results 1 to 15 of 17
09-03-2018, 07:26 PM #1Member
- Jul 2016
- Queen creek Arizona
- 94
300xs spark plugs diagnose coil issue
Hey everyone so I have a few questions, I have a 2007 300xs, has all the updated coils in it they were replaced back in 2010, but the boat is forsure down on power it struggles to plain out on a 24p bravo 1, that being said compression is all good, all injectors we’re just cleaned and given a clean bill of health, I just swapped these plugs they have one trip maybe 2 hours on them tops take a look and see what you guys think, also let me say I think from looking at the plugs it needs 2-3 coils should I replace all 6 or can o just swap what I think is bad?
09-03-2018, 09:04 PM #2
A DDT or Rinda will fire coils to test spark. Without a tool you can check coils the shade tree way with a successful outcome. Unplug fuel pump at connection just below VST. remove one plug wire at a time from coil, not spark plug.use medium size screw driver to check spark. push screwdriver firmly against head bolt or any metal part of block for grond. angle blade toward coil tower. holding at approx 1/2 inch gap. crank motor over a few seconds. If you get blue lightning bolt. Coil is good. If you get orange or no spark. Coil is bad. PS. Keep your hand on insulated screwdriver handle. Touch blade of screwdriver while motor is cranking over. Will make run out of sight to see if your nuts are still intact after smoke clears.
09-03-2018, 09:20 PM #3Member
- Jul 2016
- 94
09-03-2018, 09:21 PM #4Member
- Jul 2016
- 94
09-03-2018, 11:55 PM #5
I have the the same trust with any good working electronic part. As i have with a new untested part I would only replace a weak coil. If spark is good i would reuse.
09-04-2018, 12:07 AM #6Member
- Jul 2016
- 94
09-04-2018, 08:18 AM #75000 RPM
- Jan 2016
- Florida
- 159
Only one plug looks right there. 4th one from the left. I know I'm going to get flack from some members here but make sure they are gapped to .044. Do not gap conventional way by inserting gap tool between electrode. I use a needle nose to move s to not make contact with precious metal then use the "no go, go" method with gap tool.
Joe Perez
00 Triton TR21/14 Mercury 300XS Level 1.1 DBR Kit
09-04-2018, 10:05 AM #8
If you do not find a bad coil or two. May have leak in one of the diaphrams on fuel rail. while idling push in valve core on air rail. There may be a very light mist of water from condensation. But if there is any fuel smell at all. Change diaphram.
XstreamVking liked this post
09-05-2018, 02:58 PM #9I have 3 300xs coils listed for sale at $75 each if interested?Checkmate 2002 Convincor 270 496 MAG-HO
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
09-07-2018, 09:32 AM #10Junior Member
- Jul 2007
- Palmetto, FL
- 27
Could also be the coil wire harness. I had coils dropping out intermittently and a new wire harness is what fixed it.
09-07-2018, 04:23 PM #11Member
- Feb 2017
- Naples FL
- 74
- 27
- 9
Why are those plugs so black looking?
09-07-2018, 07:18 PM #12Member
- Jul 2016
- 94
davemvegas, Kcraft liked this post
09-10-2018, 10:28 AM #135000 RPM
- Jan 2016
- Florida
- 159
That'll do it.
Joe Perez
09-10-2018, 11:51 AM #14Member
- Jul 2016
- 94
09-10-2018, 06:39 PM #155000 RPM
- Jan 2016
- Florida
- 159
Other two? You have a fuel regulator on the other rail. Need special tools for that one.
Joe Perez
300xs Ignition Coil | Coil Harness | Harness | Power Head Studs & Bolts.....
By Pachanga_rick in forum Misc. Parts and AccessoriesReplies: 3Last Post: 08-31-2018, 02:35 PM -
Help diagnose livorsi GPS speedo issue
By gregpro50 in forum Technical DiscussionReplies: 7Last Post: 07-28-2012, 06:06 PM -
Help diagnose volvo penta trim pump issue
By gregpro50 in forum Technical DiscussionReplies: 3Last Post: 07-26-2011, 10:57 PM -
diagnose my plugs for me.
By rchevelle71 in forum Technical DiscussionReplies: 15Last Post: 10-10-2007, 06:21 AM
