Results 1 to 7 of 7
Thread: Prop setup.
08-22-2018, 04:48 PM #16000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Prop setup.
Not getting very much traction in my other thread about the boat so I thought I'd ask here. My 25 foot long 9 and 1/2 foot wide c-hawk with a 250 EFI is spinning a 17-pitch inertia to 5800 RPM at around 43.5 to 44 mph and 18% slip (calculated). At this point I believe the soft limiter is what's holding me back, I'm wondering if I'm going to buy a couple props to play with, what should I be looking at?
While topspeed is a concern, its notnTHE concern. this is a family style boat that I will pull tubers with. Right now even with the inertia and the motor set with the anti-cavitation plate about an inch above the bottom of the boat it'll cavitate if I go into a moderate to hard turn. Even with the motor tucked all the way in.
I'm wondering if I should try a 19 rev4, a 19 Mirage Plus, or 19 inertia. I'm open to any suggestions.
This is the boat, running at about 4800 RPM.
08-23-2018, 10:25 AM #26000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
All right, just went out and ran a 19 pitch inertia. RPMs are at 5500, speed came up mile and a half or so. Slip went to 22% though.
08-23-2018, 11:36 AM #3Team Member
- Lake Coochiching, Ontario
- 7,769
- 276
- 487
- 1594
- 6 Post(s)
Have you tried the prop selector on Mercury's web site? A four blade might help with the cavitation.
08-23-2018, 06:29 PM #46000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
10-01-2018, 11:53 PM #5
Each pitch is around 300 rpm.
On a boat that is not performance based ,you have a hull design that will slow you down. It's not prop slip its hull efficacy. Look up your motors wot rpm. You can add a few hundred, but dont go crazy
Patriot Missile
10-05-2018, 09:33 AM #66000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
Looking at your rig, i think u need to lower your motor,to reduce the slip & cavitation. find a used 4 blade and give it a try. my 2cts.
10-07-2018, 10:38 AM #7
Does this boat have a keel ? if so lower it so the cav plate is 1 inch under the transom.. before buying all new props I would experiment with heights. the slip figures are pretty high that your getting, are you sure of the gear ratio your putting in ?
is this definitely a 1.75 to 1 or could it be a 1.87 to 1 ? this later ratio would drop your slip to around 11.75% and that would be more acceptable .
from the manual it states this was an optional high altitude ratio ?????Last edited by phillnjack; 10-07-2018 at 10:43 AM.
Setup /prop
By Merc 2.5 in forum Props, Setup, and RiggingReplies: 4Last Post: 03-12-2018, 11:38 AM -
can you run through prop style with over prop setup
By aggiestckl in forum Props, Setup, and RiggingReplies: 5Last Post: 10-08-2012, 06:43 PM -
Prop Setup
By Guppy in forum Props, Setup, and RiggingReplies: 1Last Post: 09-14-2009, 08:14 PM -
omc prop and setup help
By bennyb in forum Props, Setup, and RiggingReplies: 2Last Post: 01-27-2009, 06:24 PM -
prop setup
By crawfish14 in forum Props, Setup, and RiggingReplies: 4Last Post: 01-13-2008, 09:43 PM
