Results 1 to 13 of 13
Thread: CCMS Reed Stuffers
08-21-2018, 05:44 PM #1
CCMS Reed Stuffers
Just received in the mail today. I wanted to post my thoughts on them. Maybe I’m looking at it wrong, but I think these stuffers will be better than shaving front half. Not only do they put reeds closer to the crank, but also keep carbs further away. Kinda like a 3/16 spacer plate. I could be wrong. Thanks Chris
08-21-2018, 06:49 PM #2
Keep us posted on the before/after comparison!
Josh Peterson
08-21-2018, 06:52 PM #3
I can’t very soon. My front is shaved already. I will use on one of my winter builds.
08-25-2018, 08:35 PM #4Member
- Mar 2017
- ohio
- 50
- 10
I put a set of chris carson reeds and stuffers in my 98 300 promax.really woke up that laser injection.i have noticed more hp and my Allison gets on plane much quicker.much better acc.and mid range.very good product.
08-26-2018, 06:45 AM #5
Are those stuffers for a 4 pedal setup or 5? I think chris said ,get the most stuffing from the 4 pedal setup? Was just curious as to what route ur taking
08-26-2018, 07:06 AM #6
I got 5 pedal. About 3/32 thick. 4 pedal stuffers will be thicker because reed blocks are shorter.
08-27-2018, 07:50 PM #7Junior Member
- Mar 2017
- Prairieville Louisiana
- 16
Hi,guys just put new ccm race reeds an stuffers in my motor today. Little info on motor an boat, 2001 ally xb2002t with 1999 xr6 150. The only mods ive done is 200 bell tuner,drilled can an mid, installed Bobs exhaust snout,velocity stacks an rejetted carbs.My motor was still running good, butt wanted to get rid of metal stock reeds,figured they were stock an nervous about sucking one threw motor.Well when i tore down this mourning one reed had half a leaf gone and a few others had tips missing,i lapped cages, installed stuffers an reeds put back together.Went to river to test my work lol an see what changed,full tank of fuel,hot as hell,windy,an high humity.Turned 6800 dam lost some of my post sorry any way, ran 83 .4 about same as normal. engine idles better an seems two have a little better low end torque.I ran boat weekend before last with half of fuel an ran 84.5.so top end probably around the same. hope this gives a little feedback to yall. Thanks Chris for parts Randy
08-27-2018, 07:54 PM #8
Is that better or worse? Not sure what your motor was turning before
08-27-2018, 08:28 PM #9Junior Member
- Mar 2017
- 16
Well lost some of my orignal post, motor turned same rpms as before 6800 today an same two weekends ago. Better idle an seems like a little more torque on bottom end,not sure on top,half a tank of fuel makes a difference on my little motor,i didnt figure changes was gonna make a drastic change,more for safety. checked compression when i got home.whew was same in all 6, same 125,dont think broken reed hurt cylinder
01-27-2023, 06:55 AM #10Junior Member
- Jun 2022
- Loxahatchee, FL
- 10
And, and, and, and, and!!!
02-01-2023, 09:38 PM #115000 RPM
- Sep 2008
- charlestown, ri
- 296
- 10
- 37
i used them on a 3cyl omc 49ci block last year. was just a fishing motor for a customer. starts were near instant, but then again it was rebuilt they all start right away when rebuilt. i couldn't notice a thing performance wise, but definitely idled smoother as you said.
02-02-2023, 12:12 AM #12
i used .060" CCM spacers on 2.5 280HP with drag electronics ussing 5 pettle sportjet cages with carbon reeds.they seemed to give a tad better holeshot..CONS is they are a royal PIA to fit!!you literlly have to take dremel and saw/grind everyone of those tiny 3mm hold down screws..ALL 60 of them!you have to do this after installing reeds and be extra careful not to nick reeds with dremel.this is only way cages will fit into front half deep enough so .060 spacer will fit..you have to grind/cut away the head (panhead)about 50%.this is a onetime use as you would never be able to use the hold-down screws in future,this is my application,so take it what it is worth.Chris and Stan are BEST in business and HIGHLY reccommend!!
"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
2007 Sportsmen Driver of the Year
rgsauger thanked for this post
02-03-2023, 07:00 AM #13Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
For what it's worth,the seven petals and sport jet 5's are the only ones that may need the screws trimmed a bit.Easiest way I think is a careful few seconds on a belt sander once the reeds are mounted,then blow off the dust.Half a minute on each side does the trick...sorry they gave you a hard time,Chris
stoker2001 liked this post
carson reed stuffers
By eli in forum Technical DiscussionReplies: 37Last Post: 07-27-2018, 09:25 AM -
Help explain reed stuffers on a v4 crossflow
By spybot in forum Technical DiscussionReplies: 8Last Post: 09-12-2017, 07:42 AM -
Mercury Tech: CCMS reed job on 2.0L
By pcrussell50 in forum Technical DiscussionReplies: 4Last Post: 07-12-2017, 12:05 PM -
CCMS 266-R Reed set
By ghost28 in forum Misc. Parts and AccessoriesReplies: 4Last Post: 05-20-2015, 04:50 AM
