Page 9 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 121 to 135 of 179
  1. #121
    Jul 2011
    Gloucester, VA
    2002 - 2005 were the only years the 300x were produced . Go to your local outboard boneyard and see how many of them are littered about ... Zero
    But there are usually same year 225 / 250's available for your choosing .
    Many of the base components are shared between the two . The ones that are not , can be modified , bought new or now better than new .
    For guys with running motors that want a little more , the best bang for the buck is to clip your heads to 64-65cc . Lighten the flywheel to aprox 13 pounds . Strip your reed blocks of the rubber coating , lap them flat and install the reed Chris Carson makes just for this.
    Easy external parts to get to . Still quiet as a church mouse and will usually pull one more pitch size prop to the same rpm .
    The 300x exhaust can has a "cats eye" hole on the side to help them idle a little cleaner as well as a hole at the base to vent some exhaust away from going thru the lower unit . I have cut the back off and left it off . I have cut the back off , made a few 2" holes and welded the whole thing back on . Each had a different level of sound .
    If you are going to cut the can off , leave the water dumps a little longer .
    Now that it's not so constipated ..
    You can't buy the X reed adapter plate from Merc any longer but these billet adapter plates and fuel rail's are available that will move the injectors , rail , harness , brackets , bridges and other junk out of the airstream ..
    It would be a good idea to put an adjustable fuel pressure regulator on the VST at this point if your mature enough to not run it lean . It will keep going faster the more you turn it left .. until it saws itself in half . The whole reason for putting it there is to keep the bottom two cylinders fat and happy ..
    There are two pretty common sense "stages" if you want to call them that . With moderate compression, it will still run on pump gas .
    Anything after that requires going into the block and doing port work big bore kits etc .
    E-85 ... Man , don't you know boaters will drive to the end's of the earth to find "wrek" fuel .. ? LOL ..
    The only thing I see wrong with it , is that it is "Hydroscopic" . The whole time the boat is in the water , near the water , or the humidity is high and the tank vent is not plugged , it would be absorbing water .
    So what thread are the fittings for the hp outlet. Getting ready to place an order for all my AN fittings and don't feel like taking my motor on the boat apart.
    I ASSume -6 is plenty
  2. #122
    Yes sir , a # 6 O-ring x #6 male to a # 6 on the run gauge port adapter is what that is ..
  3. Likes RSWORDS liked this post
  4. #123
    Jan 2008
    PERTH AUSTRALIA
    [QUOTE=Chaz;3164628]Yes sir , a # 6 O-ring x #6 male to a # 6 on the run gauge port adapter is what that is .. [/QUOT
    PM you Charlie
  5. #124
    [QUOTE=torquespeed;3164679]
    PM you Charlie
    E- Mailed ya this morning ( eastern standard time )
    Just now PM'd ya back ...
  6. #125
    Quote Originally Posted by RSWORDS View Post
    That stock brass hose barb on the left and the feed port / transfer tube on the stock fuel rail are tiny ....
  7. #126
    Jan 2018
    NE Oklahoma
    Will a 2002 300 pro XS PCM work on my 2002 225 efi? I thought I read somewhere that they were different but just wanted to be sure.
  8. #127
    Jul 2015
    northern lower michigan
    Quote Originally Posted by torquespeed View Post
    no problems at all i can reflash your ecu or you can exchange a ecu $335usd freeee shipping back to you
    your get the reflash and a tidy up of your ecu if paint is chipped will repaint and a rebadge 300 performance fuel
    and a neat torquespeed decal.
    i put a bit of detail on gear presentation added.
    PM me or leond197@hotmail.com i will send you my address for sending the ecu and i use paypal as well.
    cheers Torquespeed
    Torquespeed, What does it run for the 2-box 1999 250efi?. $335 usd a box or $335 a pair ?.. What fuel are these set up for octane wise?.
  9. #128
    Jan 2008
    PERTH AUSTRALIA
    Quote Originally Posted by big tom View Post
    $670usd a pair , standard pump gas is fine we use a BP 98 in Australia premium fuel to get the best results , running a better set of cut heads around 130 to 140 comp will get you better results on the reflash and a lite flywheel.
  10. #129
    Naples, Florida
    Quote Originally Posted by Freedom92 View Post
    1998-2000 300 Pro Max-dual ecu
    2001-2005 is 300X (2001 different coils not compatible with 2002-2005 ecu)-single Motorola ecu
    2006-current is 300xs- Single Motorola ecu
    Mercury never made a 300 "Pro XS" in a 2 stroke
    to answer your question a 300x 2002-2004 ecu will work on your motor in everyway but not with your pencil injectors. the 300x uses the pink tip khein like a laser injected 2.5L had
  11. #130
    Naples, Florida
    the 2002-2004 200/225/250efi motors are basically like Chaz said a downgraded 300x.
    The main difference internally is each horsepower has it's own port map.
    external bolt ons:
    -higher compression head
    -light flywheel
    -thicker reed plate with external pink tip injectors not the pencils
    -carbon 5 petal reeds instead of steel 6 petal
    -the throttle body is machined different inside the horn
  12. #131
    Naples, Florida
    Oh yeah!!! 300x block has a more open echaust chest cast into it unlike every other 3L including the 3.2L 300xs block
  13. #132
    Jan 2018
    NE Oklahoma
    So a list of parts to acquire would be helpful. I need to make my 225 efi as close to a 300 as I can. Any help would be appreciated
  14. #133
    Start with cutting theback of the off and unplugging the exhaust. Itsall easy after that.
  15. #134
    Naples, Florida
    www.MadEFI.com
    light weight flywheel
    300x heads
    ecu flash to 300x
    pink tip injectors
    billet reed plate
    carbon fiber reeds
    those are the bolt ons
    porting the sleeves and exhaust chest are the block mods
  16. #135
    Jan 2018
    NE Oklahoma
    Quote Originally Posted by Todd D View Post
    www.MadEFI.com
    300x heads
    ecu flash to 300x
    pink tip injectors
    billet reed plate
    carbon fiber reeds
    Yeah for the time being I'm focusing on the bolt-on parts. It's on a bass boat but I do like having enough hanging on the back to make it fun. I may later start woking on a short block as a winter project.
  1. Performance mods for mercury 250 efi
    By rico64 in forum Props, Setup, and Rigging
    Last Post: 12-26-2014, 06:40 PM
  2. Mercury 88' 2.4L 200 performance mods?
    By WFO_88_201 in forum Technical Discussion
    Last Post: 04-05-2013, 03:08 PM
  3. Mods for 2002 9.9 Mercury 2 stroke that won't blow it up!
    By TacomaTodd in forum Technical Discussion
    Last Post: 06-12-2012, 05:58 PM
  4. 1995 mercury 150hp 2.0 liter performance mods (new to S&F)
    By roughthumbbg in forum Technical Discussion
    Last Post: 06-04-2010, 07:38 AM
