Page 6 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 76 to 90 of 179
  1. #76
    Yeeeepppp ....
  2. #77
    Jan 2018
    NE Oklahoma
    Let's hope so. I'm going out in a couple of hours. I will post the results.
  3. #78
    Jan 2018
    NE Oklahoma
    Well, adjusting the TPS didnt help. If anything I might have lost 100 rpm. All I could get was 5100 rpm. What would be the next thing to look at? Could the ecm be malfunctioning?
  4. #79
    3 wire switch , which wire did you pin into ?
    How did you adjust switch ?
    I ask because when they are low ( below scale) they normally won't even start and run. Let alone run well.
    If you are in fact on the correct wire , the loss of 100 rpm .... I wouldn't run it again until I was certain the issue is not mechanical .
    I don't remember , Did you do a compression check ?
    How did the plugs look after yesterdays run . All the same , or do you have one hole that looks different ?
  5. #80
    Nov 2009
    hardyville va
    Quote Originally Posted by Freedom92 View Post
    The TPS 0's itself every time the motor starts. Never seen one go bad on your style motor. You may have a mechanical issue, sleeve turned, center main failing, and yea something could be up with the ecm.
  6. #81
    Jan 2018
    NE Oklahoma
    Top right cylinder looks just a little cleaner than the rest. Compression checked out good. We pinned the middle wire on the TPS. This thing starts up and runs just fine. Very reliable but just wont go over 5000 rpm
  7. #82
    Jan 2018
    NE Oklahoma
    Quote Originally Posted by cali kid View Post
    Sleeve turned? That a common issue with these things? How would I go about checking the ecm and its programming?
  8. #83
    Nov 2009
    hardyville va
    If the motor was run hot, the sleeves can turn. I've seen Mercs,Yamaha's with turned sleeves. No power, but runs great otherwise. It' a long shot, but something is wrong with your motor. On the ecm, you need to find one you can try on your motor.
  9. #84
    Yantis, TX
    Have you checked the relief holes in the tuner and verified they aren't carbon plugged. If you can't get air out, you certainly can't get it in.
    "We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing."
  10. #85
    Jan 2018
    NE Oklahoma
    No I haven't. How would I get to them?
  11. #86
    The mystery motor ... I usually wind up with those somehow ...
    Center wire of the three is correct.
    The ones with bad cranks in them usually had big enough chunks ate out of the journal that a bearing would drop in the hole and lock the motor up. Then it would start and run again, till it did it again. Mostly at idle, and only seen it on real early model cranks with the twin-row mains.
    They did have a run of bad X cranks that broke or lifted journal material at around 500 hours. But other than that, they have been pretty reliable.
    The honeycomb in the factory inner can ( tuner ) is for cooling. It's purpose in life is to help keep the lower gasket alive.
    Turned sleeve .. could be, if it was mine it would have moved enough that the ring would have went into the port got stuck and made a mess ...
    Did this boat run much better at one time ? And do this all of a sudden ? Over time ?
    Propped wrong ? Did you buy it this way ?
  12. #87
    Jan 2018
    NE Oklahoma
    Yes I bought it this way. When I test drove it I never ran it up to WOT because of it being such a small timber infested lake. As I mentioned before the guy I bought it off of was an older gent and his tech friend may have done something to limit this motor for safety. As far as props I have two. A Hydromotive 24p and a merc 26p neither of which will go over 5000 rpm
  13. #88
    Nov 2009
    hardyville va
    Funny, I have the exact motor outside in the pile, we are starting to rob parts off of it. Took it off a heavy center console, would not turn over 5K no matter how you propped it. Ran like a dog. Tried everything, finally put a 225 Opti on the boat and it does well. The thing would run rich and foul plugs. Wasted a lot of time on it. Was a mystery. I will tear it apart this winter to see what I can find. It's got to be mechanical.
  14. Likes Freedom92 liked this post
  15. #89
    Nov 2016
    Missouri
    You might want to do a fuel pressure reading at WOT under load, i just had an electric fuel pump that pressure tested fine at idle but under load it would drop to 20 pounds, put another electric fuel pump on it and pressure stayed at 36 pounds, used a dyno to find it.
    Daddy taught me to never force anything but to just get a bigger hammer.
    1995 19'0" Champion bass boat
    1995 200 XRI
  16. #90
    Jan 2018
    NE Oklahoma
    What would a 300 pm ecu be worth? I found one but it seems high to me. Would it be a better idea just to have my 225 efi remapped? If so how much does that service usually run? Mine is the single Motorola box on a 2002 225 efi
  1. Performance mods for mercury 250 efi
    By rico64 in forum Props, Setup, and Rigging
    Last Post: 12-26-2014, 06:40 PM
  2. Mercury 88' 2.4L 200 performance mods?
    By WFO_88_201 in forum Technical Discussion
    Last Post: 04-05-2013, 03:08 PM
  3. Mods for 2002 9.9 Mercury 2 stroke that won't blow it up!
    By TacomaTodd in forum Technical Discussion
    Last Post: 06-12-2012, 05:58 PM
  4. 1995 mercury 150hp 2.0 liter performance mods (new to S&F)
    By roughthumbbg in forum Technical Discussion
    Last Post: 06-04-2010, 07:38 AM
