Page 11 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 151 to 165 of 179
  1. #151
    Honda own's Keihin .. who knows if they started out life in a bike, car or outboard.
    What matters is that they fit the parameters mentioned above.
    If they don't .. they will operate from 36 PSI to 100 PSI , get in good with your injector guy and make sure you have adequate pump and an adjustable regulator to wind up @ 500cc / min.
    Deca injector / PCM map … your on your own !
    Pink tip …
    White tip ...
  2. #152
    Jan 2018
    NE Oklahoma
    Who would you suggest I send my single ecu to for reflash? How long is the turnaround and what's generally the cost? Just need to estimate how many pennies I have to save up to do all this.
  3. #153
    Jan 2018
    NE Oklahoma
    Thanks Chaz and Todd D for pointing me in the right direction.
  4. #154
    Get ya some "Slick 50" .. ya won't be disappointed …
    Ohh me ribs are a hurtin now …
  5. #155
    Jan 2018
    NE Oklahoma
    Will this mod require a fuel pump or fuel regulator upgrade?
  6. Thanks ratfink thanked for this post
  7. #156
    Naples, Florida
    300x copy motor with Stock crank no. Upgrade to a 3.2L crank and yes!
  8. #157
    On the adjustable regulator … depends on the maturity level …
    Keep turning it down, and it will go faster with each 1/2 pound drop in pressure … right up until it saw's the block in half …
    Please don't "axe" me how I know …
    So, here's an interesting read. Never thought about running a peak and hold injector on a system designed for saturated injectors … by just adding a resistor in line .. LOL
    https://maxxecu.com/webhelp/wirings-...r_outputs.html
  9. Likes Soporific liked this post
  10. #158
    Jan 2018
    NE Oklahoma
    What should the pressure be run at?
  11. #159
    Nov 2013
    finland
    What ecus u guys run with 300x style intake and Torquespeed Racing 59cc cnc cut heads?
    Performance 6500 or Modified 7200?
  12. #160
    Quote Originally Posted by Freedom92 View Post
    Each motor is different. Some guys have everything but compression. Some do nothing but add a too much compression .. each will require a different tune-up.
    Can't do no harm starting high 43 -45 psi. to make sure everybody's happy. Tune from there .. but 39 - 40 psi should be about the bottom , unless you have a bunch of extra injectors that flow differently and the time to bump them around from hole to hole to get all the cylinders to run the same. Tune to the worst hole , all we have is a global pressure adjustment and maybe a colder plug in the hot (lean) hole or two .
    Fuel wash on the piston crown, spark plug color, egt sensors, all reveal important info.
  13. #161
    Jan 2008
    PERTH AUSTRALIA
    Hey Chaz
    How you going mate ?
    cheers Leon
  14. #162
    Jul 2011
    Gloucester, VA
    TorqueSpeed ouwe r ya mate .. ???
    I'm full go on me practicin Kiwi, so I can hear what ya tellin me .. widout sayin it over again ...
    Now at's a niofe ... or maybe two ...
    How you say ... no worry's mate .. or Tally~ho~ the fox MF ...
    Ohh me ribs ...
    *cough* that's a nice chunk aluminum *cough*
  15. #163
    First two bumps of the key on a early model ...
    https://www.facebook.com/benny.ferna...5920904575532/
  16. #164
    Jan 2018
    NE Oklahoma
    Chaz will the billet reed plate being thicker still fit under my original efi cowling? Will I have to make linkage rods or do you offer them?
  17. #165
    Aug 2020
    lakeland fl
    Any issues with this setup? I just put 300 efi fuel and ignition on my 2001 efi I also have chris carson reeds and block stuffers.
  1. Performance mods for mercury 250 efi
    By rico64 in forum Props, Setup, and Rigging
    Last Post: 12-26-2014, 06:40 PM
  2. Mercury 88' 2.4L 200 performance mods?
    By WFO_88_201 in forum Technical Discussion
    Last Post: 04-05-2013, 03:08 PM
  3. Mods for 2002 9.9 Mercury 2 stroke that won't blow it up!
    By TacomaTodd in forum Technical Discussion
    Last Post: 06-12-2012, 05:58 PM
  4. 1995 mercury 150hp 2.0 liter performance mods (new to S&F)
    By roughthumbbg in forum Technical Discussion
    Last Post: 06-04-2010, 07:38 AM
