Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 1 to 15 of 179
    Jan 2018
    NE Oklahoma
    2002 Mercury 225 EFI performance mods
    What are some ideas and or combinations of parts to make this dog run like it's supposed to or better? XB heads? ProMax heads? ECMs? Reeds? What has worked for some of you guys?
    Tony
    Jul 2011
    Gloucester, VA
    Just got through doing this on my 225 carb motor.
    4 butterfly intake, 250 efi fuel and 300 ign ECUs, Chris Carsons reeds.
    If you want to cut the tuner go for it.
    That will wake her up.
    Jan 2018
    NE Oklahoma
    Quote Originally Posted by RSWORDS View Post
    You still have your stock heads? Mine has the ignition ecm on the side of the motor and as far as I can tell its the only one. Im wondering if the fuel and ignition are run out of the same box on the 2002 225s
    Jul 2011
    Gloucester, VA
    Nevermind. You have the 555 ecm. Whole different game.
  5. Thanks 30velocity thanked for this post
    Jan 2018
    NE Oklahoma
    So with the 555 ECM what do I need to do to squeeze some hp out of this thing. I know it needs more compression so I'm looking for suggestions as to what casting numbers to search for. And what ECM ro search for as well. I dont intend to do any tuner modifying although I would consider replacing with a 300 tuner. From what I've read on here the hot setup for previous years to mine was 300 ProMax ignition and 250 XB fuel ECMs but mine being a later model wont use the same ECMs.
    Jul 2008
    Canada
    I also have a 2002 225 EFI, trying to figure out what to do with this guy. I only see one ECM on mine as well. If you figure out what you're gonna do with yours let me know. Would love to compare notes.
    Jan 2018
    NE Oklahoma
    I certainly will. Surely one or two of the knowledgeable gents on here will offer some insight
  9. #8
    May 2017
    US / NC
    If you have the one box or ECM you most likely have a down draft engine and the ECM has to be sent off and have flashed and have your heads cut . The 300X will hurt your bottom end or hole shot and be louder. Thats what i was told . I have a 2004 225 EFI with the one box and it is the down draft engine .
    If any one want to mod there tuner or a mod tuner , i have one i would let go .That came out of my 300X Mid-section . it has been cut off about 6 inch , from the best i can remember . Going back stock .
  10. #9
    Jul 2008
    Canada
    So are are you talking about the exhaust tuner in the mid section needs to be cut, as well the heads need to be shaved, then there would be gains running the modified engine? What do you have that you want to sell and how much?
    Quote Originally Posted by RiChavis View Post
  11. #10
    May 2014
    Livingston, Louisiana
    http://www.simonmotorsports.com/popp...tinstall2.html
    Directions in where to cut tuner and installation of poppet diverter
  12. #11
    Jan 2018
    NE Oklahoma
    It is my understanding that the c2 castings are such high volume that it's of no benefit to cut them. And as far as a tuner is concerned ...if I can stick with the stock one I would probably rather do that. I dont really want it any louder.
  13. #12
    May 2017
    US / NC
    Quote Originally Posted by strat250 View Post
    No to get gains out of these motor's ...the ECM controll every thing .....so the box has to be flashed to get more gas and rpm range . And the heads cut to make up for the gain's. There are more like the Optimax motor 's. Thats how it was explain to me . then mods to the tuner to exhaust more ?
    I do know on the 300X they have a 1 inch hole in the bottom of the tuner and after market are cut to get gains .
  14. #13
    Jul 2008
    Canada
    Is it feasible to stage and upgrade out?
    EG
    Get the computer re flashed then get the heads cut etc...
    or is this a build it and flash it to the build type thing.
  15. #14
    Jul 2008
    Canada
    If I was talking about something mild eg... turning the 225 into a 250... I am looking up part numbers is the only thing different between these two the computer? I can't see any difference in part numbers between the same year 225 efi and 250 efi when it comes to pistons, cranks, Injectors, fuel pumps, intake manifold etc...
  16. Likes N/A liked this post
  17. #15
    My favorite series of engines ... all the basic stuff to build 400 HP
  18. Likes HopePusher, Laseraddict liked this post
  1. Performance mods for mercury 250 efi
    By rico64 in forum Props, Setup, and Rigging
    Last Post: 12-26-2014, 06:40 PM
  2. Mercury 88' 2.4L 200 performance mods?
    By WFO_88_201 in forum Technical Discussion
    Last Post: 04-05-2013, 03:08 PM
  3. Mods for 2002 9.9 Mercury 2 stroke that won't blow it up!
    By TacomaTodd in forum Technical Discussion
    Last Post: 06-12-2012, 05:58 PM
  4. 1995 mercury 150hp 2.0 liter performance mods (new to S&F)
    By roughthumbbg in forum Technical Discussion
    Last Post: 06-04-2010, 07:38 AM
