Results 1 to 15 of 15
    May 2017
    Phoenix
    2.5L Merc 280 Fouled Spark Plugs
    Hey Guys,
    I have a 1999 2.5L merc 280 and had some spark plug issues this past weekend (or so I suspect). Recently I took the boat to a reputable shop in the Phoenix area to have him go through the motor with me and do a compression test, hook it up to the computer... basically give the blessing on my motor. Never had an issue with it before but just wanted some piece of mind.
    They had put fresh plugs in (ran great the first weekend after the service) but not some much last weekend. The boat would almost fall on its face as it was loaded up and couldn't clear out. I took the plugs out and they were soaked. Called the dude to find out his son put the incorrect plugs in the boat. I had some BUH8's in the garage that I took out of my old boat a year ago.. cleaned them up and was able to run the boat.
    Still ran not up to par as the plugs were acting fouled and decided to get towed back in just incase it was something other than that.
    Any suggestions?? I have been told NGK BUHW plugs are what that motor calls out for... but if anyone has other input I would like to hear.
    Also thinking about getting my injectors cleaned and flow tested for cheap insurance... just for safe keeping as well.
    I run a half av-gas/91 octane mix with Mercury Premium Plus oil at 32:1....
    Any help is appreciated!!
    Thanks guys.
    -Brooks
    Folsom, Cal
    I think you posted onriverdavesplace also?anywho,i copy and pasted from Diamond website BPZ8H-N-10
    NGK
    BPZ8H-N-10 For 280hp
    Projected tip = less fouling
    Choice of top Offshore Racers
    "Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
    2007 Sportsmen Driver of the Year
  3. Thanks bdantonio thanked for this post
    Sep 2017
    Ashland city tn
    I think its necessary to have a leak down performed, it will tell the truth about health of nic bores, I'm far from expert,but how many hours you got on the rings? What did compression say?
    north carolina
    When was injectors last cleaned.
    Feb 2006
    Champ QL77CC
  7. Likes Michael J Giesler liked this post
    Mar 2006
    auckland new zealand
    Also check your reeds
  9. Thanks bdantonio thanked for this post
    Jan 2003
    aalsmeer
    You can 't run gapless spark plugs on your motor you have induction ignition not cdi
    You need sparkplugs with a ground electrode like the bpz
  11. Thanks bdantonio thanked for this post
  12. #8
    May 2017
    Phoenix
    I did, thank you for the link!
  13. #9
    May 2017
    Phoenix
    Quote Originally Posted by Merclover View Post
    I think I'm going to do that regardless now. I'm no expert myself but had a few buddies say I might need to get my ecu checked out again too. Might be dumping a bunch of fuel causing it to foul the plugs and load itself up.
    The motor has 324 hrs on it and the compression has 150psi in each cylinder.
    May 2017
    Phoenix
    Quote Originally Posted by R.grover View Post
    I was told this as well... I'm going to bring the boat home this weekend.
    Sep 2017
    Ashland city tn
    That's some impressive #s , I dont hear of that many hours on one very often, must had been babied , good luck ,I'm sure once you go down list and check everything ,u will find it
  16. #12
    May 2017
    Phoenix
    Yeah I was surprised when I saw that on the reader when we hooked it up myself. Hoping itís just those few small details, plugs, injectors, or Ecu.
    I am am going to take a look at the reeds too while Iím doing so. Iíve only had the boat for a few months now. Bought the boat as they just finished putting on the new power. Never skipped beat until this last weekend.
    May 2017
    Phoenix
    Heres a few pics of the boat and ecu. Kind of hard to see but it’s a Motorola. Click image for larger version.
ID:	416152Click image for larger version.
ID:	416153Click image for larger version.
ID:	416154Click image for larger version.
ID:	416155Click image for larger version.
  18. #14
    Oct 2015
    ont canada
    check the air temp sender
  19. Likes Bunger liked this post
  20. #15
    Feb 2007
    lily lake WI
    Flow injectors good oil 40 to 1 unless your turning it past 8 grand then32 to 1 plus try ql77cc champion for some unknown reason some ecu like them better for certain years
  21. Likes stoker2001 liked this post
  1. Cleaning Fouled Spark Plugs?
    By David L in forum Technical Discussion
    Last Post: 08-09-2012, 06:14 PM
  2. 2002 OPTIMAX 200hp fouled plugs
    By Wayne Koeppe in forum Technical Discussion
    Last Post: 07-22-2007, 11:13 PM
  3. 2.4High Po fouled 3 plugs whatcha think
    By Rob Ricci in forum Technical Discussion
    Last Post: 03-25-2007, 05:36 AM
  4. 96 Merc 225 EFI spark plugs?
    By BWard in forum Technical Discussion
    Last Post: 08-08-2006, 07:25 PM
  5. Cleaning Oil Fouled Plugs
    By PropWash in forum Technical Discussion
    Last Post: 04-27-2005, 03:53 AM
