Results 1 to 15 of 17
05-09-2003, 09:47 PM #1
Ever paint your Garage floor?? Looking for a good paint product.
Just looking for who may have had expirence with painting a garage floor and who has the best product to paint with. I heard Muscle gloss is good but pricy, any ideas?? THanks guys.
ClintThere's only two things in life you can't get rid of, AIDS and a BAYLINER !!!
05-10-2003, 08:52 AM #25000 RPM
- May 2001
- Brookfield,Wi
- 225
Garage floor coating
Daytona, my last 4 homes I have epoxied coated the garage floor rather than painting and it is the only way to go. My current coating has been down 13 years with no peeling. The secret to the job is in the prep. If it has never been painted, buy some muriatic acid and with a long handle scrub brush,brush it and rinse real thorougly,then let it dry for a day before rolling on two coats of Epoxy floor coating. Your local paint supply should be able to order it for you. I have stayed away from the water based epoxies. My garage floor stays so clean sometimes I sometimes walk out in my socks. The floor will look like a showroom if you take your time and don't rush the job. Frank
05-10-2003, 08:59 AM #3
Can you apply that epoxy over a prevoisly painted floor or is it a waste?
05-10-2003, 09:09 AM #45000 RPM
- May 2001
- Brookfield,Wi
- 225
Natzx7, I have always used Epoxy over either bare concrete or a previously epoxied floor. the problem might be in the adherance to the paint. Do you have any peeling now with the painted floor? If not you might be able to get buy by using a good degreaser to prep it. Frank
05-10-2003, 09:14 AM #5
datona19
got great results from dupont imron masonary paint.
EVERYTHING just wipes up.
looks great
no problems
painted floor in 1987Drew Virnelson
84 Checkmate
19'Exciter/Evinrude XP 2.6
best of 73.3 mps (gps)
gonna try for more this weekend!!!
05-10-2003, 09:51 AM #6
This is a link to the epoxy floor covering I was looking into. The only problem I have is that I will have over 500.00 in materials as a "kit" to do this job. I do have bare concrete but have a few cracks to contend with. Is it usually that much or is it just this company?? Thanks guys for the ideas and help.
http://www.musclegloss.com/faq.htmThere's only two things in life you can't get rid of, AIDS and a BAYLINER !!!
05-10-2003, 11:21 AM #75000 RPM
- Oct 2001
- 242
I sell these resinous flooring systems for a
living and can help you with a high-quality application.
If you have any area that will be exposed to sunlight (such as an open garage door), you will want to consider a polyurethane topcoat for UV resistance, since epoxies will "chalk", or at least fade a bit.
Log on to bhdistributors.com and/or call me Monday @ 800.844.5860 so we can discuss.
BTW, someone mentioned the important thing here is surface preparation. We've long maintained the three keys to our business are:
1) Surface preparation
2) Surface preparation
3) Surface preparation
05-10-2003, 03:29 PM #8
XS I will contact you, generally the garage door is closed but open fron 5 pm till 10 pm & by that time the sun is west enough no direct light gets in there ( my garage faces south). I do need to fill some cracks and generally clean the floor but it has no bad oil stains or anything like that. I believe it was 530 sq feet total that would be painted and I would like to do a gray color to be neutral but other colors considered. Please leave me your name so I can ask for you or my number is (989) 249 7630 if you need to make contact. Thanks.
Clint.There's only two things in life you can't get rid of, AIDS and a BAYLINER !!!
05-10-2003, 09:47 PM #95000 RPM
- Oct 2001
- 242
Give me a ring when it's convenient,
ask for Eric.
Sounds like you don't have much of a UV issue there, but you still may consider an aliphatic poyurethane topcoat for a durable, high-gloss finish.
We have lots of choices as we represent several manufacturer's of these systems. Can take care of the crack issue as well, you have a few options there also.
05-12-2003, 07:51 AM #105000 RPM
- Richmond, Corrotoman River, VA
- 257
You might want to cosider VCT tile. I was going to epoxy mine until I looked at the cost and amount of prep.
I put down black and white VCT, cost about .55 a sqare foot including the glue, I think. Few coats of wax every now and then and it looks great. If you damage a tile, just cut it out and put a new one down. Covers flaws in the floor too.
It may be harder to keep clean though, and you will need to strip it every so often to get tire marks out. Otherwise, colors and patterns are up to you.
05-13-2003, 09:24 AM #11
Just last night
used a product from Rust oleum (SP).
Went on real easy....and used 3 kits for my garage...at like 50.00 a kit.
we'll see how it lasts?
K.K.
05-13-2003, 09:52 AM #12
KK, I've seen that rustoleum stuff advertised. I will be curious to see your results. I also saw some stuff (epoxy) in Griots Garage, they are real proud of that stuff. I think I figured it would cost me about $1,000 to do my garage.
I would like to do something but am not sure how long I will be staying at the current residence. I am watching this one with interest.Half B - Just one more project away from the promised land.
1994 Allison Grandsport with 260 2.5 EFI and wounded 1988 HST
05-13-2003, 10:33 AM #13
Wanna see way cool
and ya can take it with ya when ya sell your place.... WWW.RACEDECK.COM
Check out a place called Garage werks.....don't have web address you will have to search....but that decking is way cool to make your own patterns!! BUT TO RICH for my blood!
But you can take it with you.
I will take photos and post them soon as I can of what I did.
I went with the Beige color...easy as hell to apply !!
Also gonna do my basement with the rust oleum basement epoxy in Beige also.
I will post photos of that when done also....once I drive on it I will let ya know what happens in the garage of course that won't be until the end of the month!
K.K.
05-13-2003, 02:53 PM #14
Damn!!! If I bought that I wouldn't have ta worry bout moving the garage would be my new quarters. Even if I wanted to move I doubt I would have any $ left.
05-14-2003, 11:44 PM #15Junior Member
- Jun 2002
- Waycross, Ga
- 27
sherwin williams
i did mine. bought epoxy paint system from sherwin williams a couple of years ago if i remeber correctly it was about $130 for 2 gallons covered about 400 square feet thin coat wish i would have bought more and put it down thicker still looks good though
the only thing i found that will stick to it is fiberglass resin if you let it harden.
