Results 1 to 1 of 1
    Jun 2012
    Cape Cod Ma
    1985 Hydrostream Vector 17'
    " VINTAGE " 1985 Hydrostream Vector 17 foot Performance Boat. This Hydrostream was parked in inside a barn in Maine for 15 years. Solid boat and transom, turn key boat. Blue and Silver Metal Flake and Black all Original. The engine is a 1989 EFI Mercury Laser V6 220HP. 2.4Liter. Hot Foot throttle pedal, Mercury Quick silver controls. 5 inch CMC aluminum mechanical Jack Plate. 20 gallon bow tank. 2 gallon oil tank, Oil injection. New trailer tires, galvanized float on bunk trailer, fits a 1/78" ball. Comes with a 27 pitch Mazco RE 3 blade solid hub performance stainless prop, and 1, 3 blade stainless hole shot prop. 2 life jackets , 2 ignition keys . Boat runs around 70 mph , it does Not have a low water pickup installed. Steering system has a single teleflex cable. Engine runs very well and clean burning, Engine PSI is 120 lbs psi all 6 cylinders. Mercury Lower Unit has Mercury High-Performance Synthetic gear oil. Overall the boat is in very good condition for 32 years old. As far as i know the boat has not been ripped apart to replace any core, as paint and gel looks untouched. Boat, trailer, and clear transferable boat title. professional gear oil filler with some high performance gear oil in it. Serial # HSP554VTG585 HULL ID Boat is located in Massachusetts. Traveling alot no time to use it, otherwise would keep this great boat. Price $5500.00 Send a message here , *** Please Note*** this is not social media like face junk and twitter, please do not leave inaccurate comments on My Boat Listing Website, send me a Private Message if you have a problem or question. Thank You, and thanks for viewing my 1985 Hydrostream !
ID:	415811   Click image for larger version.
ID:	415812   Click image for larger version.
ID:	415813   Click image for larger version.
ID:	415814   Click image for larger version.
ID:	415816   Click image for larger version.
ID:	415817   Click image for larger version.
ID:	415818   Click image for larger version.
ID:	415819   Click image for larger version.
ID:	415821   Click image for larger version.
ID:	415822   Click image for larger version.
  2. Likes LetsBoat liked this post
  1. 1985 Hydrostream Vector Boat Only
    By rankink in forum Hulls up to 20'
    Last Post: 09-07-2016, 01:53 PM
  2. 1985 hydrostream vector DIY paint job what do I need
    By Drostream in forum Appearance Mods
    Last Post: 12-14-2012, 03:10 PM
