Results 1 to 5 of 5
08-16-2018, 07:05 PM #1Junior Member
- Jun 2016
- athens ga
- 9
Block differences and compatibility mercury 2.5 fishing motor
I have a 2001 Oring headed 200.
i have option to buy a 1994 head gasket 200 powerhead
will my intake, stator and flywheel work on the 1994 block?
Any other differences that may present problems during swap?
Thanks
08-16-2018, 07:09 PM #2
All that should swap rite over, lots people deck the blocks for gaskets, also some guys like o ring better?
08-16-2018, 07:12 PM #3
Front half of the block should accept any 2.5 Intake , same with stator flywheel, just use your complete system. Unless it's a optimax
08-16-2018, 07:49 PM #4Junior Member
- Jun 2016
- athens ga
- 9
08-17-2018, 05:33 AM #5
you will notice tha 'lectrics mounting bosses or gonna be different on tha '94.. it was a "switch box/coil motor 'lectrics.. 2001 is a 'lectronic" motor.. no switch boxes/cdms.. will need ta use '01 divider plate and etc.. jus look both over good and note tha difference in mounting stuff between tha two...………
XstreamVking liked this post
Mercury 150-200 V6 fishing motor
By powrguy in forum Engines WantedReplies: 1Last Post: 09-27-2014, 10:30 PM -
Mercury 2.5l fishing motor
By solaction in forum Engines WantedReplies: 0Last Post: 05-13-2014, 06:04 PM -
Any differences between 2.5 HP and Fishing Motor Mid Sections?
By Propster in forum Technical DiscussionReplies: 0Last Post: 08-16-2007, 10:23 AM -
Mercury Reeds for fishing motor
By basswalleye in forum Technical DiscussionReplies: 2Last Post: 11-09-2005, 07:03 AM -
86 mercury 150 fishing motor
By whereyat in forum Technical DiscussionReplies: 1Last Post: 11-07-2002, 06:26 PM
