Results 1 to 10 of 10
Thread: 250 Pro XB heads
08-16-2018, 06:05 AM #1Member
- Jan 2018
- NE Oklahoma
- 66
- 7
250 Pro XB heads
What are the casting numbers for 250 Pro XB heads. A guy is trying to tell me it is C-2. That's what I have on my 2002 225 efi. Is he full of it or are they actually better heads than the ones I already have on the motor?
08-16-2018, 07:12 AM #25000 RPM
- Dec 2007
- Alma, Ar
- 167
- 15
I think it is C-11 for XB and C-10 for Pro Max. C-2 is standard 225 head.
08-16-2018, 07:20 AM #3Member
- Jan 2018
- NE Oklahoma
- 66
- 7
That's what I'm leaning towards too. This guy is trying to pass off C2 heads as Pro XB heads and they are the same ones that my EFI 225 has.
08-16-2018, 07:43 AM #45000 RPM
- Dec 2007
- Alma, Ar
- 167
- 15
C-11 heads have 65-67 cc, C-10 has 63 cc per Chaz on this site. C-2 has 73 cc but I have personally seen them with 78 cc.
08-16-2018, 07:55 AM #5Member
- Jan 2018
- NE Oklahoma
- 66
- 7
Thank you sir that's very helpful
08-16-2018, 10:17 AM #6Member
- Jan 2018
- NE Oklahoma
- 66
- 7
08-16-2018, 10:35 AM #75000 RPM
- Dec 2007
- Alma, Ar
- 167
- 15
Don't believe him. They are different.
08-16-2018, 10:46 AM #8Member
- Jan 2018
- NE Oklahoma
- 66
- 7
If they weren't different there would be no sense in different casting numbers. From what I've read there's little to gain by surfacing these either. Better to get ProMax or Pro XBs to start with.
08-17-2018, 09:32 PM #9
08-18-2018, 08:03 AM #105000 RPM
- Dec 2007
- Alma, Ar
- 167
- 15
They were on a 2000 225 20" mid that I got hold of with a bad crankshaft. I think it had a replacement power head on it as it did not have the serial no. plug in it. The reason I think it was a factory powerhead was after I pulled a head to look at the bores and measured them they measured 3.6265 and the crosshatch looked great. It also had the bleed line system like the 95/96 225(according to merc manual). I gave it a light hone and put a different crank and fresh rings, ran it a few hrs and checked compression. It was 95. So I pulled a head and cc'd it and it was 78cc.
Changed my crossflow heads, standard to 135hp heads, Wauwwww
By JohnsonV4 in forum Technical DiscussionReplies: 31Last Post: 01-21-2015, 04:14 AM -
Custom Billet Heads vs Stock Cut Heads
By 95RapidRiot in forum Technical DiscussionReplies: 8Last Post: 01-13-2008, 02:43 PM -
Merc Hi-perf. 2.5 Hemi Heads Vs Stock Shape Heads
By DonChicho in forum Technical DiscussionReplies: 4Last Post: 03-01-2004, 03:47 AM -
2.4 breakin, hi comp heads, or stock heads?
By WATERWINGS in forum Technical DiscussionReplies: 7Last Post: 05-27-2003, 10:04 PM
