Results 1 to 10 of 10
Thread: ISO 1991, Merc 200 hp
08-15-2018, 11:15 AM #1Member
- Sep 2005
- northern IL
- 33
- 7
- 7
I need a 1991 Merc 200 hp 2.5 power head
I have one need to build a matching set.
I'm ready to buy what do you have running or not is OK.
Parts to build or a 7 pedal reed intake with carbs.
Thank you
09-01-2018, 08:46 PM #25000 RPM
- Mar 2018
- NJ
- 196
- 10
Are you still looking for a 1991 powerhead.
09-01-2018, 11:53 PM #3Member
- Sep 2005
- northern IL
- 33
- 7
- 7
Yes.
I sent you a PM
09-04-2018, 04:02 PM #4
I have a late 90's 2.5 200. It is a XRI motor but could sell it minus the EFI so you could use carbs. PM me if interested.
09-05-2018, 12:14 PM #5Member
- Sep 2005
- northern IL
- 33
- 7
- 7
Thanks Mikej I need the 91 200
09-06-2018, 10:04 AM #6
Steel sleeve motor?
09-06-2018, 10:18 AM #7Member
- Sep 2005
- northern IL
- 33
- 7
- 7
09-10-2018, 08:58 AM #8Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
The front 7 reed is fine use the later blocks with out the exhust slot.....I have if you need....
10-07-2018, 08:16 PM #9
I got one with no compression reliefs EE block
10-07-2018, 08:21 PM #10Member
- Sep 2005
- northern IL
- 33
- 7
- 7
I will pm you Thanks
OMC Tech: 1991 175 Silverstar Eagle vs. 1991 175 Intruder & FastStrike
By skimmabird in forum Technical DiscussionReplies: 6Last Post: 03-13-2014, 07:57 PM -
Mercury Tech: Merc 200 hp 1991
By nacimientobound in forum Technical DiscussionReplies: 5Last Post: 06-05-2013, 01:03 AM -
help merc 2.5 1991
By stavros in forum Technical DiscussionReplies: 8Last Post: 12-18-2007, 07:40 AM -
1991 225 Merc EFI
By Alan Nelson in forum Technical DiscussionReplies: 0Last Post: 04-08-2002, 09:23 PM
