Results 1 to 10 of 10
Thread: length and o.d. of water tube?
08-08-2018, 01:08 PM #15000 RPM
- Jul 2012
- wareham MA
- 309
1996 2.5 175 fishing motor, and i need a water tube. can someone check what the specs are on your copper water tube please? I need to make my own, nobody local has one available
08-09-2018, 06:15 AM #25000 RPM
- Jan 2004
- Lindenhurst, NY
- 658
- 88
- 64
- 3375
- 267
20" or 25"?
08-15-2018, 07:27 PM #3
Just saying that a 1/2" copper pipe for water like at the depot or menards will not work, its close but not correct.
08-15-2018, 09:44 PM #4
Think I have one
08-16-2018, 09:28 AM #5
If eli doesn't have one, I think I have a 25" that you can cut
08-16-2018, 09:20 PM #6
18 1/8 x 3/4 inch i have here
08-17-2018, 04:32 AM #7
08-17-2018, 02:52 PM #85000 RPM
- Aug 2010
- Arlington, VA
- 177
- 43
- 45
- 14
If the OP doesn't want or need the tube, I'd be happy to buy one from a member. 3/4 inch is too big.
The size the bullet123 listed sounds about right.
PM sent to bullet123, but I'm not trying to weasel in and "beat" the OP out of a water tube.
The OP may have found one, tried to make one (as they indicated), or maybe just isn't checking in on the forum.
If anyone else has one, please post. I need onf for a 20" lower unit, but I'm happy to cut down a tube from a 25" lower unit
-Phil
P.S. -- I'll also post in the parts wanted thread if I don't see a reply here.
Cheers!Last edited by pjbrownva; 08-17-2018 at 03:05 PM. Reason: Updated text
08-17-2018, 03:02 PM #95000 RPM
- Aug 2010
- Arlington, VA
- 177
- 43
- 45
- 14
FYI to all, I posted a WTB in the "Parts Wanted" thread, and indicated that I need the part, and another forum member likely also needs the same part. I'll post here and/or PM the OP if I get a lead on more than one of these parts. I'm sure that there are few floating around with the forum regulars, and I assume that we'd be able to find two of them easily.
https://www.screamandfly.com/showthr...t-merc-V6-2-0L
FYI.
-PhilipLast edited by pjbrownva; 08-17-2018 at 09:32 PM.
08-17-2018, 08:54 PM #105000 RPM
- Aug 2010
- Arlington, VA
- 177
- 43
- 45
- 14
OP. ((@aaron78viper), Bullet123 has one from a 25" motor that can be cut-down, and merclover has one that's from a 20".
Both are reasonably priced. You can PM them directly.
I'm planning to buy one of them, but there's another available for you if you're interested.
-Phil
Water tube length?
By whipper in forum Technical DiscussionReplies: 5Last Post: 06-23-2017, 04:40 AM -
Length of water tube
By outasite in forum Technical DiscussionReplies: 0Last Post: 03-06-2016, 10:02 PM -
water tube length
By Chummy in forum Technical DiscussionReplies: 1Last Post: 07-23-2011, 10:46 AM -
Water Tube Length
By TNT in forum Technical DiscussionReplies: 1Last Post: 07-14-2011, 06:24 AM
