Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 49
Thread: Mariner 175
    Apr 2018
    Maine/Ma
    okay that helps....I've looked at new or rebuilt powerheads but they come bare so I'd need a donor engine to get all the bolt on stuff (fuel, electronics, flywheel, etc) if I went to EFI, or if the parts off my 2.4 175 would bolt on but would that be restricting any gains from going from 2.4 to 2.5L?
  2. #17
    Apr 2017
    pa
    5 Post(s)
    "FF" blocks are more desirable if you are gonna do some porting mods to the block IMO. If you ran a bone stock "EE" against a bone stock "FF", not gonna notice much of a difference if any at all. Slap a 2.5 200 on there with some cut heads, good tuner and a good set of wh 22's or wh 46's carbs. Let'er eat!
  3. #18
    Apr 2017
    pa
    5 Post(s)
    Does your motor have a water cooled regulator or rectifier?
  4. #19
    Sep 2017
    Ashland city tn
    I thought I seen the ee block was a 175
  5. #20
    Apr 2018
    Maine/Ma
    No idea, how would I identify that?
  6. #21
    Apr 2017
    pa
    5 Post(s)
    "cc" 175
  7. #22
    Apr 2017
    pa
    5 Post(s)
    Water cooled regulator would be behind coils. All of your electrics will swap unless you have a water cooled regulator. no big deal though, you can just run a rectifier instead. Very cheap. give me serial number and I can look it up
  8. #23
    Apr 2018
    Maine/Ma
    0c218563
  9. #24
    Apr 2017
    pa
    5 Post(s)
    Water cooled, 40 amp. All of your electrics will swap, but the regulator. You will have to get two new smaller regulators for the 2.5. I figured your motor was a 16 amp, but is 40.
  10. #25
    Sep 2017
    Ashland city tn
    Quote Originally Posted by bullet123 View Post
    "cc" 175
    Ahh u r correct but ff is only one matched to promax ,according to Perry (wrenchin) I found the post but I'm not good enough on compiter/phone to move it to this thread
  11. #26
    Apr 2017
    pa
    5 Post(s)
    Yes, porting is close. All im saying is a stock "EE" will run ride beside an "FF". If you are planning on doing port and chest work, "FF" is better starting point.
  12. #27
    Apr 2018
    Maine/Ma
    this sounds like the way for me to fly then but will it fit under my stock 175 drop on cowl? If it will, any chance someone could furnish me part numbers of what I need to obtain to make this a reality?
  13. #28
    Apr 2017
    pa
    5 Post(s)
    Do you have a clamshell cowl? splits down the middle when you take it off?
  14. #29
    Apr 2018
    Maine/Ma
    no, it has three latches...one in the front center and one at each rear corner.
  15. #30
    Apr 2017
    pa
    5 Post(s)
    It should work fine. I thought I read on here you had a clamshell.
  1. 85 Mariner 2.0 150 Complete with Mariner 260 Cowl and Pan
    By 85allison in forum Outboard Engines
    Last Post: 03-12-2015, 07:35 AM
  2. Brand new Mariner Cowls... show us your cool mariner stuff!
    By Mike Nass in forum General Boating Discussion
    Last Post: 09-13-2014, 09:06 PM
  3. Mariner Magnum VS Regular Mariner
    By XstreamVking in forum Technical Discussion
    Last Post: 09-02-2010, 07:08 PM
  4. 1987 Mariner 150 1989 Mariner 175
    By Gilles1 in forum Technical Discussion
    Last Post: 08-10-2007, 07:56 AM
