Results 31 to 45 of 49
Thread: Mariner 175
08-10-2018, 10:07 AM #31
You should be able to get every part you need from this site. Lots of helpful people here. Find a powerhead and we will help you from there.
08-10-2018, 10:21 AM #325000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
I really appreciate the information, would I just order a powerhead like a ME-P6-34-N from a Mercury dealer or would I be better getting one more hand built by a reputable shop?
08-10-2018, 10:25 AM #33
There's a few 4 sale here ,and u could take it (if wanted) to a shop and have some porting and boring done, be cheaper way out imo, or buy one ready drop on and rebuild later
08-10-2018, 10:25 AM #34
Builder on here. You can probably get a rotating assembly for around $2500. Built right with good pistons. Start a post in engines wanted
08-10-2018, 10:27 AM #355000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
awesome, thank you!
08-10-2018, 10:32 AM #36
Bullet is correct that an ff and an ee are both 200 blocks. The ff has Promax porting but it is 200 Promax porting. Many seem to think they can get any ff block and have the 225 Promax with a few modifications. The 225 block is a nn and there are differences. Post a picture of your powerhead. Sometimes pics are worth a thousand words.
RockTeam Junk
08-10-2018, 11:27 AM #375000 RPM
- Jul 2007
- Appleton,WI
- 238
Not to hijack this thread but what are the differences between the FF block and the NN block? I'm looking at a 200 pm right now but don't want to pull the trigger until I know all the details.
You are correct when saying that a lot just assume (myself included) that they can put a 7 petal front,change the ECU, & put tighter heads on the 200 pm & now it's a 225 pm. Some say same porting between the FF block 200 efi's & the Promax & some say they differ ever so slightly. Some say that when ordering new sleeves the FF sleeve part# is the same as for the PM. So much conflicting info out there that I'm starting to get confused.Last edited by A-train-97; 08-10-2018 at 12:55 PM.
X-Stream Vegas
08-10-2018, 11:39 AM #38
Exhaust porting is different. I don't know why there is so much hype on trying to make a 225 promax anyway. Don't get me wrong, they are a very good motor. It depends on what you want out of your motor. If you are just worried about top speed on a lighter hull. go with the PM. I prefer better hole shot and mid range, which is what you get out of a 4 or 5 petal fishing 200 2.5 with a few mods. JMO
08-10-2018, 11:58 AM #39The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
08-10-2018, 12:59 PM #405000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
Really?.....so with the cut heads and better reeds it probably is at 200 already but about at it's max.
08-10-2018, 01:05 PM #41
200 at crank. 175-180 at prop. 200 2.5 bone stock is over 200 at prop
08-10-2018, 01:15 PM #425000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
08-10-2018, 01:19 PM #43
If you know what you are looking for and price is right. No holes in block and crank is good you would have a good start for a build. I just bought one 2 months ago for $200 with no lower unit.
08-10-2018, 01:23 PM #445000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
thanks for the info, not sure if it's complete and what's wrong but might be worth checking out or keeping my eyes open as our season winds down for a good donor.
08-10-2018, 01:29 PM #45
Problem with the xri is finding a working ecu. More than likely it is bad. Very hard to find a good working ecu. That’s another reason I use carbs. You can jet a carb much cheaper and easier than remapping an ecu. You can throw carbs on an xri, just change intake and add some bleedlines.
FORBESAUTO liked this post
85 Mariner 2.0 150 Complete with Mariner 260 Cowl and Pan
By 85allison in forum Outboard EnginesReplies: 2Last Post: 03-12-2015, 07:35 AM -
Brand new Mariner Cowls... show us your cool mariner stuff!
By Mike Nass in forum General Boating DiscussionReplies: 24Last Post: 09-13-2014, 09:06 PM -
Mariner Magnum VS Regular Mariner
By XstreamVking in forum Technical DiscussionReplies: 1Last Post: 09-02-2010, 07:08 PM -
1987 Mariner 150 1989 Mariner 175
By Gilles1 in forum Technical DiscussionReplies: 1Last Post: 08-10-2007, 07:56 AM
