Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 50
    Apr 2014
    St. Petersburg
    1997 25’ Lighting Hi-Speed Catamaran
    -Florida Title in Hand
    -Stepped Hull
    2006 – Verado’s w/ HD Lower Units
    Verado Electronic Shifters
    Verado Smart Craft Gauges
    30” SS Bravo One - 4 Blade
    5” Go Free Simrad Chart Plotter / GPS
    Fusion Radio Headunit
    - w/ JL 6.5” Co-Axel Speakers
    Total Fuel Capacity 56 Gallons
    - (2) 28 Gallon Fuel Tank’s
    Bob Machine Shop Jack Plates
    Steel Tandum Axle Trailer
    Full Sunbrella Boat Cover
    Awl Craft Painted
    Stainless Rub Rail
    (2) 12V Batteries
    Perko Battery Disconnects
    Boat Does 80 mph on GPS, this is with 4 people. The boat is not set up for top end speed, but very easily could be dialed in for much more speed if you wish to go faster. This boat is virtually a maintenance free speed boat, starts every time. You won’t have to change spark plugs, add oil, smell the smoke, listen to loud engines, or worry about getting up on a plane like the 2 strokes. The lowend torque with these motors makes this boat a blast to drive and enjoy your time on the water not working on the boat.
    Serious Offers Only!
    Asking $40,000
    Located in Pinellas County
    Runs 30 mph @ 2800 RPM approx. 2.5mpg
    Runs 40 mph @ 3800 RPM approx. 2.0 mpg
    Runs 60 mph @ 4800 RPM approx. 1.8mpg
    Runs 80 mph @ 6000 RPM approx. 1.7mpg
    Attached Thumbnails Attached Thumbnails 2018-08-05 12.27.24.jpg   2018-08-05 11.49.13.jpg   2018-08-05 11.50.57.jpg   2018-08-05 11.19.46.jpg   2018-08-05 11.22.58.jpg
  2. Likes kragar liked this post
    Mar 2009
    FLORIDA
    how many hours on the engine's and is there a trailer
    Apr 2014
    St. Petersburg
    Quote Originally Posted by ROBERT SIANO View Post
    There is a steel trailer included. Approx. 1300 hours on motors.
    Dec 2006
    Mt. Laurel, N.J.
    I've never heard of a lightning cat. Is it a copy? How many did they make?
    Does it have a balsa core? Wood transom?
    Have you had a recent survey?
    Can you provide a motor compression and leakdown test?
    DDT hours and rpm readout available?
    Azure AZ259, 8.1
    Apr 2014
    St. Petersburg
    LIGHTNING POWER BOATS - MANUFACTURER (see attached Boat History Report)
    - many people say the bottom part of the hull is like a 24' skater and the top side of the hull is like a motion - (I can't verify just people comments)
    Boat is constructed of fiberglass
    -Transom was professional rebuilt with Marine Grade Plywood and encapsulated with Fiberglass.
    The motors (20" shafts) were not new when they were mounted, as the boat was completely retrofitted in 2016/2017
    -New Transom
    -New Awl Craft Paint Job Rub Rail Up
    -New Non Skid
    -New Interior
    -New Stainless Steel Rub Rail
    - 2017 New Wiring (Marine Grade) New LED Navigation Lights, Bilge Pumps, New Fuse Panel
    - 2017 New 2 Gauge Battery Wires, New Perko Switches
    - 2017 New Verado Rigging, including new shifters, new harness, new smart craft gauges
    - 2017 New Fuel Water Seperator Racors
    - 2017 New Hydraulic Steering Lines
    - 2017 New Bob Machine Shop Jack Plates
    -Fully Serviced Engines (once prior to installing) and about 25 Hours ago.
    I have put approx. 125 Hours on the motors since finishing the boat. no issues. I would be happy to get compression testing numbers, but the reality is I would want to do it with the buyer so they can see the numbers for themselves and not take my word for it. I don't have DDT reader, but serious Buyers are more than welcome to have the motors checked out. The motors run flawless. I hope this answers your questions.
Name:	Boat History Report.pdf
ID:	414711Click image for larger version.
Name:	Screen Shot 2018-08-07 at 12.30.09 PM.png
    Victorville, CA
    What state is Pinellas County?
    Jul 2018
    Tampa, FL
    Fl.
  9. #8
    Apr 2014
    St. Petersburg
    St. Petersburg, Florida
  10. #9
    Dec 2006
    Mt. Laurel, N.J.
    The bottom is solid glass? No balsa coring?
    Azure AZ259, 8.1
  11. #10
    Apr 2014
    St. Petersburg
    Im sure the Stringers are wood cored, Im not 100% on the bottom itself.... I believe its solid glass, just from what I can see on a visual inspections. Honestly, I do not know for sure tho.
  12. #11
    Dec 2006
    Mt. Laurel, N.J.
    Did they replace the wood floor when they did the interior and transom?
    Azure AZ259, 8.1
  13. #12
    Apr 2014
    St. Petersburg
    yes, all new.
  14. #13
    Dec 2006
    Mt. Laurel, N.J.
    This hull really needs to be surveyed
    Azure AZ259, 8.1
  15. #14
    Apr 2014
    St. Petersburg
    Feel free to have it surveyed if you have interest. I would be happy to make the boat available.
  16. #15
    Apr 2014
    St. Petersburg
ID:	414992Click image for larger version.
Name:	2015-08-18 12.01.57 HDR.jpg
ID:	414993Click image for larger version.
Name:	2015-08-18 12.02.52 HDR.jpg
ID:	414994Click image for larger version.
Name:	2016-01-21 09.19.12 HDR.jpg
    Here is a few photos, I can assure you there was no expense spared. One photo shows its foam cored. All wood was removed and replaced during the retrofit. I hope this helps answer anyone's questions.
  1. Led lighting, and ground effects lighting...
    By morgantwo2 in forum Tow Vehicles and Trailers
    Last Post: 09-14-2018, 08:43 AM
  2. Replies: 0
    Last Post: 11-09-2010, 06:04 PM
  3. Idle Speed question for 1997 Mercury 2.5 Promax
    By HST Madman in forum Technical Discussion
    Last Post: 09-12-2004, 05:08 PM
  4. 1997 2.5 Offshore/19ft.tunnel Ready For More Speed
    By liberatorx2 in forum Technical Discussion
    Last Post: 06-11-2002, 08:48 PM
