Results 1 to 15 of 29
Thread: Ramdom or no fire
08-05-2018, 02:02 PM #1Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Ramdom or no fire
Hey Guy's,,1st time on this site....1990 JOHNSON 225(looper)...When I got the motor 3 yrs ago it had a failing stator,,,I jerry rigged from another burnt stator a copule of the coils & made mine work..That lasted about a year and a half or so then my stator totally fried....Replaced with a new OEM stator & to be safe a OEM Pwr pack.....That worked for while and then stated random fire(fire today none tomorrow) I found my new 3-4 month old stator was fried...I then replaced with another OEM stator & a OEM voltage regulator..... It once again worked for while & then random fire again...I the replaced with a OEM new trigger so @ this point all electrical has been replaced with OEM new & still random fire.....Since Hurricane Harvey I have swaped pwr packs & a couple of stators that were used,,,same thing pwr today none tomorrow,,,maybe the rt bank today maybe the lf tomorrow & then one time all hit & I ran it for 2 weeks in the driveway making sure it was not going to fail..The day I hooked up to the truck to get back in the water NO FIRE I even have swapped flywheels around....I am totally disconnected from the helm gang plug,,,,,black & yellow kills all 3 that are on the engine are disconnected...I have worked in the automotive/diesel mechanical field so i'm not a total dumb ass,,,, two boat shops that I deal with can't figure out it & both stated it has to have fire but I don't....At this point I have fire on #2 only...I am so depressed Anyone that can please give me your 2cents worth it would be greatly appreciated....I am open to calls also,,,i'm desperate 361.249.8722
08-05-2018, 03:08 PM #2
Feel ya pain buddy, well you have come to a good place for your fix, there are some of the best omc guys here. They will steer you in the right direction when they see this. I'm not a omc guy so I don't wanna steer you wrong,,I will say my buddy has a small omc that's doing the same thing, so I will stay tuned. Good luck
08-05-2018, 03:34 PM #36000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
To me it means looking for something lose or broken wire, fuse (the bus type can do that)
and thats a lot of testing ohm and v-drop, and you can miss because it was good when tested.
08-06-2018, 03:42 PM #4Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
System test
08-06-2018, 04:02 PM #5Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Sure appreciate your help,,,hopefully someone will steer me in the right direction.
08-06-2018, 04:06 PM #6Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
I agree,,,,I have looked & looked for a broken or bad wire,,,cleaned din pins & connections with muratic acid & reassemble with aviation oxgard-same thing,,, then a buddy turned me on to this site...I will stay in touch if I may.
08-06-2018, 04:39 PM #7
Need start by testing the stator with ohm/dva
08-06-2018, 05:17 PM #8Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Yes Sir,,,I'll get back to ya ASAP with my findings.,,Thanx Again
08-09-2018, 08:40 PM #9Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Stator OHMed out OK,,,,even compared readings with 2 other used stators,,,,mine is only a few months old considerating I've been down for a year,,,,,,still @ this time the pwr pack is only sending fire to #2,,,,,I'm wondering when my prior stator burned it possibly did something to the new pwr pack I had replaced.....Something is burning out the stators & the problem dominoes from there,,,I'm going to do more elec checks again this weekend,,,,the frustration is killing me cause I hate to lose so I a'int giving up.
08-18-2018, 01:12 PM #10Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Have put another stator on that the pwr from a running engine,,,,,no change,,,fire still on #2 only,,,sure sounds like my new pwr pack has gone bad?
08-18-2018, 01:14 PM #11Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Meant to say put another stator on that I borrowed from a running engine.
08-18-2018, 02:59 PM #12Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Sounds like it is not turning over fast enough to generate spark. They need to turn a minimum of 250RPM on the starter to have spark on all cylinders.
08-18-2018, 03:19 PM #13Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Already did that,,put 3 different starters on it & all three ran the same speed,,,the battery is hot so it's something else,,,,Thanx,,,keep throwing ideas,,,,keep this in mind,,,it ran for ten days straight a coulple months back then started the ramdon fire again only this time the fire continually is only on #2,,,,before all this now sometimes the rt bank would hit,,,sometimes the lf,,,,I've never seen anything like this
08-18-2018, 03:54 PM #14
Disconnecting the kill , black /yellow st, anywhere but at the pack is not completely eliminating that part of the system..still could have a ground or partial resistance to ground on the pwrhead harness or interupter harness/switch.. just to make sure,you dont have the cdi high performance system do you... everyone i know with this system has had random issues.. Are you checking with plugs in or out.. I know it seems stupid but a weak starter/ bad connection/cables/ battery can drive you nuts one one of these engines they have to turn over fairly fast to have cranking spark.. Put a battery charger on with start capability when its not firing and see what happens..Just eliminating problems because sounds like you have changed just about everything else..Dave
08-18-2018, 03:55 PM #15
crap posting same starter stuff as al , still can be in adequate wire size, also where is the battery..
No fire
By davmor in forum Technical DiscussionReplies: 7Last Post: 07-10-2012, 08:07 PM -
Boat Fire Near Fire Island
By Fandango in forum General Boating DiscussionReplies: 2Last Post: 06-01-2009, 05:56 PM -
Big Fire !!!!
By Simon in forum General Boating DiscussionReplies: 31Last Post: 10-30-2003, 12:04 PM -
RI Fire
By Hack02 in forum General Boating DiscussionReplies: 3Last Post: 02-21-2003, 07:11 PM
