Results 1 to 3 of 3
Thread: Wrong Shaft Length
07-30-2018, 08:29 PM #1New Member
- Jul 2018
- Savannah, Ga
Wrong Shaft Length
I have a 21' Bayliner Rendezvous boat with a 1998 Mercury 150 with a 20" shaft on the boat. The outboard has very low compression on one cylinder and the others are low as well. I have recently purchased a 2004 Yamaha 150 hpdi with a 25" shaft. Will a jack plate with the ability to raise the motor that 5" be sufficient and will that work with my boat?
Thank you in advance for any and all advice.
07-30-2018, 09:42 PM #2
probably no
07-31-2018, 08:18 AM #3Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
If your motor is mounted at it's very lowest possible position flat on the transom, you may get away with it. But as eli indicated it will not likely be ideal. Also your transom may not be designed for a jack plate lifted up to max height all the time. Puts a lot of strain on the transom.
Want To Buy 3.0 LH sporty 1 piece or 2 shaft length no matter... 1.62 small shaft
By vw-nut in forum Lower UnitsReplies: 0Last Post: 10-31-2015, 06:58 PM -
O/B shaft length
By retro rocket in forum Technical DiscussionReplies: 2Last Post: 12-13-2008, 03:27 PM -
How to measure shaft length?
By Astroglass 200 in forum Technical DiscussionReplies: 2Last Post: 06-18-2007, 07:36 AM -
shaft length
By levi beard in forum Technical DiscussionReplies: 0Last Post: 06-11-2007, 05:30 PM -
Shaft length??
By Bill H in forum Props, Setup, and RiggingReplies: 0Last Post: 12-11-2004, 11:45 AM
