Results 1 to 14 of 14
Thread: Early 90s 2.5 200 carb
07-30-2018, 07:07 AM #1Member
- Jan 2018
- Baltimore
- 41
FF Block. 1 bad hole, needs a sleeve and a piston. Strong running motor before it blew. No gearcase, exhaust can is drilled at the bottom. Will part out if interested. Located in Baltimore, local pickup only for whole block. Came on the boat I bought, sold the boat when the motor blew. Looks like there was a little salt water use prior to me owning it but very minimal corrosion. I had the powerhead off a few weeks ago, no stuck bolts everything is well lubed. Make me an offer.
07-30-2018, 07:20 AM #2
Im interested. looks like #2 is scuffed pretty good. #4 is screwed. Crank probably shot. saltwater? Can you pull starboard head and post pics? Thanks
Rdeangler liked this post
07-30-2018, 07:26 AM #3Member
- Jan 2018
- Baltimore
- 41
Fresh water only. Pulled the starboard and all was good in there but forgot to take pics. I can pull it again this week and take pics. I think the carbs need to be cleaned and flowed. I'll get more pics tonight or tomorrow.
07-30-2018, 07:32 AM #4
no need. Ill take your word. looks like rear of cowling pan is cracked also. PM me what you think its worth and we will talk. Im about 2 hours from Baltimore.
08-07-2018, 07:32 AM #5Member
- Jan 2018
- Baltimore
- 41
bump
08-07-2018, 07:38 AM #6
It also has hd clamp with single ram
08-12-2018, 01:11 PM #7
5 or 7 petal front?
08-12-2018, 01:40 PM #8Member
- Jan 2018
- Baltimore
- 41
Not a 7 pedal. Stock fishing motor front.
08-12-2018, 06:27 PM #95000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
Humm..I thought all FF had Big front ?
08-12-2018, 07:12 PM #10
I’ve never seen one yet
08-12-2018, 08:27 PM #115000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
One What ?
08-13-2018, 04:34 AM #12
I have never seen an "FF" 7 petal personally. Maybe Im just unlucky
08-13-2018, 07:11 AM #13
Wasnt 91? The only 2.5 fishing motor with 7 pedal?
08-13-2018, 07:38 AM #14
That's what I thought. I will start another thread in tech forum.
Early early 200 merc
By Tripps in forum Misc. Parts and AccessoriesReplies: 0Last Post: 08-30-2016, 07:25 PM -
Mercury Tech: Carb Floats for Mercury 2.4 WH Series Carb
By DirtySouthMikey in forum Technical DiscussionReplies: 0Last Post: 10-24-2012, 03:21 PM -
Bought 1997 Merc OS Carb 225 3.0, and parts motor EFI..Can I use efi on carb engine
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 02-19-2012, 08:59 AM -
carb problem early 80s evinrude 115
By RippinLipInMiami in forum Technical DiscussionReplies: 11Last Post: 09-15-2011, 09:10 AM
