Results 1 to 14 of 14
    Jan 2018
    Baltimore
    Early 90s 2.5 200 carb
    FF Block. 1 bad hole, needs a sleeve and a piston. Strong running motor before it blew. No gearcase, exhaust can is drilled at the bottom. Will part out if interested. Located in Baltimore, local pickup only for whole block. Came on the boat I bought, sold the boat when the motor blew. Looks like there was a little salt water use prior to me owning it but very minimal corrosion. I had the powerhead off a few weeks ago, no stuck bolts everything is well lubed. Make me an offer.
ID:	414042Click image for larger version.
ID:	414043Click image for larger version.
ID:	414044Click image for larger version.
    Apr 2017
    pa
    5 Post(s)
    Im interested. looks like #2 is scuffed pretty good. #4 is screwed. Crank probably shot. saltwater? Can you pull starboard head and post pics? Thanks
  3. Likes Rdeangler liked this post
    Jan 2018
    Baltimore
    Fresh water only. Pulled the starboard and all was good in there but forgot to take pics. I can pull it again this week and take pics. I think the carbs need to be cleaned and flowed. I'll get more pics tonight or tomorrow.
    Apr 2017
    pa
    5 Post(s)
    no need. Ill take your word. looks like rear of cowling pan is cracked also. PM me what you think its worth and we will talk. Im about 2 hours from Baltimore.
    Jan 2018
    Baltimore
    bump
    Apr 2017
    pa
    5 Post(s)
    It also has hd clamp with single ram
    Dec 2016
    Florence,ohio
    5 or 7 petal front?
  9. #8
    Jan 2018
    Baltimore
    Not a 7 pedal. Stock fishing motor front.
  10. #9
    Aug 2006
    GA
    Humm..I thought all FF had Big front ?
  11. #10
    Apr 2017
    pa
    5 Post(s)
    I’ve never seen one yet
  12. #11
    Aug 2006
    GA
    One What ?
  13. #12
    Apr 2017
    pa
    5 Post(s)
    I have never seen an "FF" 7 petal personally. Maybe Im just unlucky
  14. #13
    Sep 2017
    Ashland city tn
    Wasnt 91? The only 2.5 fishing motor with 7 pedal?
  15. #14
    Apr 2017
    pa
    5 Post(s)
    That's what I thought. I will start another thread in tech forum.
  1. Early early 200 merc
    By Tripps in forum Misc. Parts and Accessories
    Last Post: 08-30-2016, 07:25 PM
  2. Mercury Tech: Carb Floats for Mercury 2.4 WH Series Carb
    By DirtySouthMikey in forum Technical Discussion
    Last Post: 10-24-2012, 03:21 PM
  3. Replies: 2
    Last Post: 02-19-2012, 08:59 AM
  4. carb problem early 80s evinrude 115
    By RippinLipInMiami in forum Technical Discussion
    Last Post: 09-15-2011, 09:10 AM
Eddie Marine - Horizontal
