Results 16 to 30 of 41
Thread: V8 pro xs ECM?
    35 Post(s)
    Software "Flash" (Over-write) = No Warranty
    Quote Originally Posted by Jamie Nichols View Post
    What happens if I just throw on whatever prop runs the best without a tech? Warranty problems for the owner?
    Yep...………….unless you mess with the software.
  2. #17
    Mar 2017
    redondo beach, ca
    Seems strange, if this were the case any "traction control" would eliminate all over the hub props and surface application's.
  3. #18
    May 2007
    STL
    Big problem for our world for sure
    [IMG][/IMG]
  4. #19
    35 Post(s)
    Question Over The Hub Examples
    Quote Originally Posted by madmatic View Post
    All of the ProXs displays had thru-hub exhaust. In fact, they're busy trying to develop plugs for Fury prop ventilation holes that the 2 strokes needed. I don't know how their software accounts for "slip" (surface).
  5. #20
    Aug 2018
    On a racetrack or at the lake
    Quote Originally Posted by WaterZebra View Post
    I had read someone who bought a new Fury said the blades were different and figured that the design change was for more bite with the greater lowend torque of the new 4-strokes.
  6. #21
    Aug 2018
    Is the adaptive speed control what y'all are talking about acting as a "traction control" and is it only on models with digital controls?
  7. #22
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by PRE-Z06 View Post
    They all are I drive by wire when you get technical. On the traditional control rigged motors the potentiometer are just under the cowling.
  8. #23
    Western Pennsylvania
    I'm sure it's going to be tuff to hack into the ECU?
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  9. #24
    Aug 2018
  10. Likes Jamie Nichols liked this post
  11. #25
    Feb 2017
    Naples FL
    Ouch that's not cheap.
  12. #26
    I have a 200 Pro XS V-8 on a Tidewater Carolina Bay 20' with a 19 Tempest Plus 6200 rpm and 58 mph. I have not noticed anything strange when prop testing seemed just like any other to me.
  13. #27
    Aug 2018
    Considering the price difference between a 200 and 300hp PRO XS, I'd say it is as you don't need the flash tool and can ship ecm to them and buy throttle body for about $1200 to gain 100hp.
  14. #28
    Feb 2017
    Naples FL
    I'm still waiting to hear that it is that simple before considering a 225. I don't need to be worrying about legal issues or insurance claim loop holes.
  15. #29
    St. Pete Fl
    There won’t be any reason to mess with the throttle body. It is bigger than the engine needs and does not open 100%. The reason for needing a tech with a lap top is due making sure the engine reaches full load. The engine is only going to turn a certain rpm so you want to prop it to reach as close as possible to 100% load. These engines use the same pcm as the catalyst sterndrive engines and also uses a wide band o2 sensor
  16. #30
    May 2007
    STL
    300r has short intake runners whatever those are per marketing
    [IMG][/IMG]
