Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 41
Thread: V8 pro xs ECM?
    Feb 2017
    Naples FL
    V8 pro xs ECM?
    Has anyone tried re flashing them yet? I'm hoping that the 200, 225 and 250 are capable of 300hp.
    Sep 2014
    Quote Originally Posted by Jamie Nichols View Post
    You and everyone else. I have heard the intake runners are different on 300r don’t know if it’s true or not.
    #skaternation
    21 rally sport (sold)
    21 Cougar (sold)
    21 Skater (sold)
    24 skater (sold)
    21 Armstrong (fishing deck) 250 etec
    24 SEB (soon to be laid up)
    Feb 2017
    Naples FL
    I'm not concerned about the R versions. The standard fishing motors cost too much as is.
    Cams on the R are different too.
    I have a friend doing some digging to find out if it’s just a map. If it is I’m consodering two for my 24 Skater mapped to 300 with 3.0 sportys
    Aug 2018
    On a racetrack or at the lake
    I asked Simon and he said they haven't gotten their hands on one yet, has anyone with parts catalog access compared heads, cams/valve springs, injectors, throttle body part #s to see if they're the same?
    Feb 2017
    Naples FL
    I haven't found the parts schematics yet.
    Aug 2018
  8. Likes Jamie Nichols liked this post
  9. #8
    Feb 2017
    Naples FL
    Someone mentioned needing a tech with a computer to test props with the new Mercs? No way I'm paying a merc tech to test props! Could this be true?
  10. #9
    35 Post(s)
    Merc Techs - Prop Tests
    Merc techs analyze the data from the ECU based on whatever props you want to try. The ECU will remember every prop combination you test. The software will adjust the engine's parameters to make any prop run "perfect" but the data may tell you to try running a higher pitch etc, to optimize fuel economy, etc That's what the Merc tech will be doing.
  11. #10
    Feb 2017
    Naples FL
    Quote Originally Posted by WaterZebra View Post
    What happens if I just throw on whatever prop runs the best without a tech? Warranty problems for the owner?
  12. #11
    There is a cavitation control acts like traction control on a car. If the motor senses it the ecu will pull timing and reduce power automatically. My buddy has set up a few v8 now and one on a ranger was limited by this. He said you could trim out feel it adding speed but as soon as it did the ecu would pull power and lose speed. This is something that would have to be turned off in most high performance applications. This was on a 250XS v8 I’m not sure if the 300R has this or not.
  13. Likes Jamie Nichols liked this post
  14. #12
    Feb 2017
    Naples FL
    This really turns me off from wanting the new Mercury.
  15. #13
    8 Post(s)
    what no burnout button??
  16. #14
    Hopefully it can be tuned out like optimax will go into guardian mode and reduce power if your on the rev limiter for a few seconds. That’s a scary situation when ur approaching 120 in a light tunnel boat with a big prop and a non ratcheting case.
  17. Likes powerabout liked this post
  18. #15
    Aug 2018
    Imagine it's not that intrusive as it'd be surging while chopping through rough water?
