Results 1 to 2 of 2
07-22-2018, 10:21 PM #15000 RPM
- Jul 2011
- canada
- 216
- 9
- 7
Suggestions for a better torque tab 2-hole CLE
Im running a 2 hole CLE case on our Eagle one tunnel and it is right on the edge of blowing out at top end of 90mph. The case has the large skeg with the built in torque tab, which in my opinion isnt doing enough compared to my 200 case with an added tab.
What would my best course of action be for adding a tab to the CLE? Simply add a tab like I did on the 200 case or build it up with epoxy and shape it as I like?
07-23-2018, 04:55 PM #2
Im using the same 2 hole case and had a issue with the tab not being enough to deal with the torque steer, i did a search on here and seen people were having good luck using pc-7 epoxy to make there own tabs. Nice thing is you can add and subtract from it to suite what you like. Im going on 4 seasons now.
checkmate45 liked this post
15" 2 Hole CLE Lower, 15" 4 Hole Lower, 25" 2 Hole Lower, CLE Case - Cleaning House.
By Pachanga_rick in forum Lower UnitsReplies: 9Last Post: 09-11-2015, 04:48 PM -
Where do I drill second hole on torque master for water inlet
By Donat in forum General Boating DiscussionReplies: 8Last Post: 08-14-2015, 01:15 PM -
How much torque tab and how (already have a TH marine torque tamer)
By Mr. Demeanor in forum Props, Setup, and RiggingReplies: 15Last Post: 10-04-2010, 08:51 PM -
2-hole VRS 4-hole CLE lower units...
By jrumon in forum Technical DiscussionReplies: 12Last Post: 04-15-2004, 10:42 PM -
Hole to fill in a hole in transom?
By Jeff_S in forum Fiberglass and Composites DiscussionReplies: 6Last Post: 03-25-2003, 11:44 PM
