Results 1 to 15 of 25
07-22-2018, 01:09 PM #1
Blew up my 300X this weekend. Looking for reputable rebuilder in Michigan.
Blew up my 300X this weekend. Burned a hole through the center port side piston, others appear to be okay still. A little concerned what caused the one to go bad? Just prior to the blow up, I notice the last couple of times I was out in the boat the tach needle was bobbing all over when it was above 3-4 thousand rpm, it seemed to run fine, but it was down a couple of mph off the top end speeds it typically would run (I assume the piston was melting down the last couple of times out and just finally let loose). My first thought was it was a faulty or dirty injector? But I have been reading there can be issues with the coil drivers in the ecm and it can cause timing issues which can lead to a melt down on a cylinder (wondering if this has something to with my tach needle jumping around). Motor had around 450 hours on it and has always run perfectly fine until this. Looking for at least a good machine shop in MI that is familiar with doing blind hole outboard motor blocks. Possibly would also like to have a shop that can clean the injectors and reset the ECU to break in and check the drivers in them to make sure ECU or coils were not an issue. Looking for recommendations in the MI area. Thanks.
91 Lavey Craft Sebring 20.8 / 02 Mercury 300X
2006 Seadoo RXP 215
2003 Seadoo XP DI
1995 Seadoo HX
1992 Kawasaki Jetmate
1987 Kawasaki 650SX
1986 Kawasaki X2
07-22-2018, 03:14 PM #2
Best off to call Jay Smith Racing.......
07-22-2018, 03:55 PM #3
If you want to keep it in Mich. then Capt. Insane-O is your man .. !
Lynn .. PM that man your number
MeCapnDave, specboatops liked this post
07-22-2018, 06:25 PM #4
07-22-2018, 07:00 PM #56000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,229
- 55
- 297
- 2737
- 3853
What’s going on with the piston above the bad one?
07-22-2018, 07:25 PM #6
Second for captninsano.
07-22-2018, 07:26 PM #791 Lavey Craft Sebring 20.8 / 02 Mercury 300X
2006 Seadoo RXP 215
2003 Seadoo XP DI
1995 Seadoo HX
1987 Kawasaki 650SX
1986 Kawasaki X2
07-22-2018, 07:56 PM #8
Jay smith does not build 3L
Best guy to deal with is Quinton.
The 300x they build are top notch
07-22-2018, 08:09 PM #9
07-22-2018, 08:21 PM #1091 Lavey Craft Sebring 20.8 / 02 Mercury 300X
2006 Seadoo RXP 215
2003 Seadoo XP DI
1995 Seadoo HX
1987 Kawasaki 650SX
1986 Kawasaki X2
07-22-2018, 08:30 PM #11
So your sayin I needed my glasses for both issues ... LOL
I stand corrected sir .. !
I looked and said to myself , thats right where this other one I got here broke the crank . And that sleeve looks eroded pretty bad , even though the piston hasn't been steam cleaned … Then I said no need in speculating … but only took down crank part .
07-22-2018, 08:37 PM #12
You just made me go double check though!!! LOL! Popped the head off again and the deck surface it nice and smooth, you can see the gasket was sealing fine, and the piston is nice and square in the bore and travels smoothly when you turn the motor over. The motor initially stuck the piston and stopped, but after it sat for a second unstuck and fired right back up. I could have made it back to my folks cottage, but I could hear the piston rattling a little when it started so I shut it right back down and did not want to chance hurting the block or crank by running it any more than I had to.
2006 Seadoo RXP 215
2003 Seadoo XP DI
1995 Seadoo HX
1987 Kawasaki 650SX
1986 Kawasaki X2
07-23-2018, 09:34 AM #13
What the hell is going on with these things, that's the third one in a week, anyway I left my # in reply to your pm.
07-23-2018, 10:08 AM #146000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Ign issue kill it? Picked up a 250 powerhead that looks identical. Haven't had a chance to dig into it.
07-23-2018, 03:47 PM #15Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
My motors never have these problems.... 10years.... my axel broke......boat safe from H2O....
300x Rebuilder in Florida
By Nick225EFI in forum Technical DiscussionReplies: 2Last Post: 02-07-2016, 04:35 AM -
Mercury Tech: Trying to find reputable rebuilder for mercury 2.4 bp
By rude sleekcraft in forum Technical DiscussionReplies: 23Last Post: 03-27-2014, 02:32 PM -
Any reputable builders of high perf. 2.5 Mercs in Michigan
By jdewaard in forum Technical DiscussionReplies: 7Last Post: 03-14-2013, 01:58 PM -
Michigan this weekend....
By WARLOCK in forum General Boating DiscussionReplies: 2Last Post: 11-09-2010, 11:47 AM -
Michigan City IN, this weekend
By yachter55 in forum Upcoming Events, Races, and GatheringsReplies: 0Last Post: 08-04-2010, 09:01 PM
