Results 1 to 15 of 18
    May 2001
    Possum Hollow Resort, Texas
    Supercharged Mercury V8's on the horizon??
    Having a new cat built over the next few months. Rather than rigging it with 400r's as I originally planned I'm tempted to sit and wait a bit. Is there any gossip or rumors floating around of higher hp engines based on the new 4.6L V8's? I'd wait a year if indeed something bigger is on the horizon rather than buying the current 2.6L 400R's.
    Anybody heard anything related to this?
    Thanks,
    David
    Jan 2017
    Albany NY
    There are tons of rumors, but that’s all they are. Maybe someone else has more details but I’m sorry to say I doubt your gonna get any factual information.
    Jan 2008
    Daytona Beach Florida
    Quote Originally Posted by poorboy View Post
    Thanks,
    David
    Big Thunder just ran their 32’ cat with 400R’s with a factory supplied tune to 450 hp. Mercury Racing is hard at work tuning more HP and with this big displacement platform. It’s inevitable that some big HP is going to be available soon !!
    Jun 2018
    Floating around
    With a four stroke its pretty easy to boost it. Superchargers require more outfitting with bracketry and whatnot but turbo charging would be pretty simple. Controlling it is the challenge and if Merc has their A game on they already have 3bar map potential and tuning suites for the racer crowd and their own future growth plans. If not Holley controller or if your more of a self doer then megasquirt would work too.
    Its really all about what fuel you can handle running. Even in stock NA trim at 87 octane and that mild idle? Add cam/s and compression and theres a lot to gain. Im sure the future is filled with heavy modded 4 strokes
    Mar 2017
    Miami, FL
    I don't think supercharging is on the horizon for this motor unfortunately. Mercury wants to keep everything in house, and they aren't in the supercharger business. There is rumors of a V10. I am not really sure what Mercury plans to do with the 350 and 400 Verado replacements. But you have to assume it is coming. The I6 Verados do not meet current emissions standards. I do hope they can make it to 350 NA on this V8 block
    May 2001
    Hickory NC
    I wonder with how light they were able to get the powerhead if it has enough structural integrity to handle boost or even more power.
  7. Likes powerabout liked this post
    Dec 2001
    Mk 20h...70lbs...Champ hotrod...50 lbs. The later like threaded rod straps. Had both and both were good....
  9. #8
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by Radiant View Post
    Who was/is manufacturing the verado superchargers?
  10. #9
    Mar 2017
    Miami, FL
    I am not sure. Just what I have been told before
  11. #10
    Oct 2009
    Gonzales, La
    IHI, I believe.
    Oh, and my money is on a 550 lb 375 hp v10 and then a 590 lb 450 hp v12.
  12. #11
    May 2016
    keys
    NA motors won't be able to stay EPA compliant for long. There going to have to add some sort of forced induction. I think a turbo setup would be lighter than supercharged.
  13. #12
    8 Post(s)
    Quote Originally Posted by Whaaaaat View Post
    if the EPA look at CO emissions 4s outboards are going to get a hard time or its cat cons to add to the weight...
  14. #13
    May 2016
    keys
    Cats are coming! Then the fusion to direct injection, optimax 4strokes. Weights will go up more and more as they add emissions crap to the package. I'll bet $50 that if you pull the power head on one of these and look down in the mid you'll see right where the cat will mount.
  15. #14
    Dec 2013
    georgia
    IMO mercury will not make the same mistake twice putting supercharger on this v8 like the did the verado. It's opens the door for anyone to flash ecm for more power something mercury has no control over. A verado 200hp flash to 325hp a 400r flash to 455hp. Mercury will control the hp gains in this v8 with good old proven technology bore, stroke ,cams,intake design. So no v10 also why because its cheaper to add higher compression pistons to get 50hp on 90 octane
  16. #15
    Jan 2017
    Albany NY
    Yup I agree, then they will try to counter the weight with lighter weight parts, with expensive materials which will drive the price up.
  1. Replies: 0
    Last Post: 02-12-2015, 10:42 AM
  2. Mercury Supercharged vs. Mercury Opti-Max
    By jag3639 in forum General Boating Discussion
    Last Post: 08-06-2012, 06:19 AM
  3. 557 HP Mercury V-8 Supercharged outboard???
    By 4-strucked in forum General Boating Discussion
    Last Post: 03-27-2012, 08:20 AM
  4. Mercury Unveils New Verado 135, 150, and 175 HP 4-Cylinder, Supercharged Engines
    By Scream And Fly in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-27-2005, 10:57 PM
  5. Mercury Unveils New Verado 135, 150, and 175 HP 4-Cylinder, Supercharged Engines
    Last Post: 02-19-2005, 02:29 PM
