Results 1 to 2 of 2
07-20-2018, 01:25 PM #1Junior Member
- Apr 2016
- Lake Conroe, TX
07-20-2018, 10:44 PM #26000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
The standard from factory settings what you change are
engine height ( less lower unit drag more rpm: drawback if in rough water a lot you can lift out)
mor bow or stern lift ( no draw back but you can fiddle with it forever trying to get that perfect 3-5 degree angle on the final lift surface)
actually getting on the last strake, on pad, or other surface. ( drawback some hulls even though it’s there can get squirrely: my tv18 is one of the few that will lift about 50 it gets spooky in a breeze )
hole shot ( really personal choice here some will ride bow up for a bit for a few mph up top: more prop searching and $$ finding that perfect hole shot vs top end. )
Stick with that prop till you red line after adjusting the other stuff. More or less to see if pitch is good. You could already be on the wall.
Others will jump in with more specific to your hull info.
1995 gambler 209 te Yamaha 225 yamah ox66 prop suggestions
By Ktp22 in forum Bass Boats and Sport Fishing RigsReplies: 2Last Post: 07-10-2018, 12:43 PM -
Yamaha Tech: Suggestions for Yamaha 90 parts - Thanks
By Air Dog in forum Technical DiscussionReplies: 0Last Post: 04-07-2010, 01:53 PM -
Rebuilding 225 yamaha excel - Any suggestions?
By flyboy in forum Technical DiscussionReplies: 3Last Post: 06-29-2005, 12:00 AM -
Suggestions for a new Prop
By dvracer in forum Props, Setup, and RiggingReplies: 4Last Post: 06-08-2004, 11:04 AM -
yamaha excel suggestions please
By bully in forum Technical DiscussionReplies: 26Last Post: 10-09-2003, 07:52 AM
