Results 1 to 7 of 7
Thread: 300XS trim cylinder leaking down
07-19-2018, 04:14 PM #1Junior Member
- Mar 2015
- Virginia
- 11
I just bought a 30' Spectre with twin 300XS motors and am having a problem with the trim cylinders on the right motor. Hoping someone can shed some light on what is going on.
I can trim up both motors in my garage and slowly the right motor will start losing trim. You can actually hear the cylinder make a sound as the motor goes down. When running boat I leave the trim at parallel and that motor will go into negative trim during acceleration.
I have checked all lines and there are no leaks. The motors have 135 hours.
07-20-2018, 04:57 PM #25000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
Have you checked fluid levels? Made sure release valve is closed tight? If all checks out the valves are probably leaking which explains the slow decent. Do you have a service manual? If you do in the trouble shooting section it'll show you the culprit to your problem. I had the same problem it turned out the relief valve was slightly open. If your valves are leaking you can send it in and have them replaced
07-20-2018, 05:07 PM #3Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Manual release valve on starboard side. O-ring goes bad and will let it leak down real slow. You might get lucky and it is just turned out some. Big straight slot screwdriver is the tool. Valve is plastic so go easy on it. Just check and replace the o-rings.
07-20-2018, 05:39 PM #4Junior Member
- Mar 2015
- Virginia
- 11
Thanks for the responses.
All lines are tight. Don't see any leaks. Fluid level is right at the minimum line. Fluid appears to be red like transmission fluid.
I have the Mercury racing trim pumps mounted inside the boat and I don't see any valves on them. Unfortunately I do not have the service manual.
07-20-2018, 07:03 PM #55000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
. Since you did the initial trouble shooting the seals on your valves probably need replacing. That should take care of your problem.
07-20-2018, 07:04 PM #65000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
07-20-2018, 07:49 PM #7Junior Member
- Mar 2015
- Virginia
- 11
Leaking Hyd Cylinder
By Tom Foley in forum Technical DiscussionReplies: 1Last Post: 12-31-2007, 01:14 PM -
OMC V4 tilt cylinder leaking at pigtail
By Riverman in forum Technical DiscussionReplies: 3Last Post: 07-11-2007, 07:39 AM -
Leaking steering cylinder
By Naiscoot in forum Technical DiscussionReplies: 1Last Post: 03-14-2007, 09:58 PM -
Power trim cylinder leaking fluid
By zmoz in forum Technical DiscussionReplies: 4Last Post: 08-02-2005, 04:17 AM
