Results 1 to 11 of 11
07-19-2018, 12:59 PM #1Member
- May 2018
- Norway
- 42
- 7
E tec 250 powerhead on ficht midsection
I have a 250 ho etec powerhead i am considering buying, but i do not have anything to put it on. I can get a 250 ficht 2003 With a blown powerhead very cheap. Will the etec powerhead fit the ficht?
07-19-2018, 04:33 PM #2
The 250HO is a 3.4L motor and uses a different adapter plate than a 3.3L Ficht. The exhaust passages are smaller on the 3.4. You will need to either modify the 3.3L adapter or get one for a 3.4L...
Dan Cario
1994 STV Mod-VP w/225HO Ficht Evinrude
1987 22' Velocity w/225HO Evinrude E-Tec
07-19-2018, 05:13 PM #3
i just finished swapping to a 20" mid with my 225 (3.3L) I set mine on a complete mid from a '93 evinrude 140 and had no problems. You will need the correct adapter pate and inner exhaust housiing like Baja16 stated.
07-20-2018, 03:56 AM #4Member
- May 2018
- Norway
- 42
- 7
Great, thanks!
07-25-2018, 02:02 PM #5New Member
- Mar 2013
- jackson
Tobb1, I am looking for 250HO Powerhead...where did you find it? THanks
07-25-2018, 02:23 PM #6Member
- May 2018
- Norway
- 42
- 7
A local workshop has one in stock, it was replaced under warranty as it was seized. But it turned out it was only the flywheel that was jammed when that was freed up it was running again. But i got a very nice 250 ficht 2003 that has one cylinder seized almost for free so I am going that route instead.
michaelshilling thanked for this postmichaelshilling liked this post
07-25-2018, 02:34 PM #7New Member
- Mar 2013
- jackson
Thanks
07-25-2018, 05:26 PM #8Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
You will need a set of e-tec lower pans and cowling as it will not fit under a ficht hood
04-23-2022, 03:37 AM #9Junior Member
- Mar 2022
- Finland
I have same problem but opposite. 2003 250 powerhead and 250 3.4L etec adapter and exhaustpipe. Because nothing else is available. Does exhaust heat rise too much because 3.4l exhaust is smaller?
07-24-2022, 12:24 PM #105000 RPM
- Aug 2019
- Palmharbor
- 557
- 20
- 58
- 150
2003 powerhead can and will fit any 90 and up mids like ocean pro and venom just need hose barbs for exhaust plate drilled and tap an base gasket installed for your year easy peezy
01-14-2023, 11:21 AM #115000 RPM
- Aug 2019
- Palmharbor
- 557
- 20
- 58
- 150
Yes it will fit as long as it isn’t a G2 starboard /starboard block engine that has the square bolt on. Cowling
1999 175 FICHT Powerhead
By deCler in forum Misc. Parts and AccessoriesReplies: 0Last Post: 05-18-2018, 03:01 PM
