Results 1 to 3 of 3
    Sep 2012
    United States
    A STV equivalent for the highway
    Some have asked about my car in my avatar. It is a 1923 Track-T roadster that was built to be very lightweight at 1790 lbs. Most all Track-T roadsters are powered by a 4 cylinder in line engine like a Pinto and if built as light as mine scoot pretty good. I'm running a Scott Shafiroff Dart block 427 built to mild specs so only 525 hp at 5600 rpm. Instead of a typical slushbox automatic transmission, I'm running a Tremec TKO-600 5 speed manual with a 0.64 5th gear. I like a comfortable ride so am using a Jag IRS with 3.54 gears feeding 31" M/T radials.
    Over its life I have run 3 different engines and two different transmissions.
    The first engine was a 355 sbc built to be a peaky high rpm screamer into a Muncie 4 speed. It dyno'ed 386 hp and ran 10.4 in the 1/4 mile at Sacramento Raceway and 10.4 on my G-Tech confirming its accuracy and why the auto magazines put so much faith in the numbers it generates. The one and only drag at Sacramento Raceway was a bit of a con job on my part. It was the Wednesday night run what you brung events and I had heard that their scales were down for repair. I show up at tech and they asked me how much my Track-T weighed and I replied with a straight face 2100 lbs. Then they asked about hp and with the same straight face said it was a 250 hp crate engine. Mr Tech crunched some numbers and declared it was possible I could run mid 12's and since I didn't have the safety equipment to run in that bracket he wouldn't normally let me run. But since I was an old guy he would allow it but there wouldn't be a car in the other lane for safety. That 10.4 pass cemented that without a lot of safety gear like roll bar, 5 point harness and a lot of other stuff, I wouldn't be allowed to run in the future.
    The 2nd engine was built for as much torque at the lowest possible rpm as can be had out of a sbc. 350 block, 400 crank so the longer stroke for torque plus special cam with a profile that produced more torque than the typical RV cams on the market. I knew in this build I was going to give up a lot of peak hp and the dyno sheet confirmed this with only 320 hp on a built 383 that normally would be in the 450 hp range, a loss of 130 hp. The torque peak was at 2800 rpm and 516 lb/ft. This engine would be perfect for rock crawlers. This is what I got in return, able to cruise up 6% grades at 900 rpm in top gear at 45 mph with no engine rattle and have the ability to roll on more throttle. Highway cruising at 65~70 mph and get a bit over 30 mpg. Of course a penalty in the 1/4, turning an 11.4 et.
    The current engine runs 9.7 et. Highway cruising 17 mpg which beats the 1st engine's 12~14 mpg.
    Rather innocent looking isn't it?
    Bob
    Northern and Southern California
    WL7GS Whiskey Lima 7 Gone Sailing
  2. Likes Capt.Insane-o liked this post
    Jun 2018
    Floating around
    Dont think I've ever called a roadster a sleeper before but I would definitely not expect that thing to run a 12, let alone a freakin 9! Yee gads man that must be white knuckle all the way
    Sep 2012
    United States
    Not at all. I'm 65 and have mellowed over the years. With the 383 torque motor I could just short shift and keep the rpms around 900 to 1500. It was a sweet and tame little pussycat. The 355 (1st engine) protested if I rolled on the throttle below 2500 rpm. The 427 behaves a bit better but still doesn't like to work hard below 2000 rpm.
    Bob
  1. 26 Pitch Big Ear Chopper (Or equivalent)
    By MacGyverJB in forum Parts Wanted
    Last Post: 04-20-2015, 04:28 PM
  2. Loctite 518 equivalent..?
    By Ted Stryker in forum Technical Discussion
    Last Post: 06-13-2010, 05:43 PM
  3. Raker Equivalent?
    By HydraSport179V in forum Props, Setup, and Rigging
    Last Post: 03-17-2010, 12:53 PM
  4. fuel curve % on a 260-what is the jet size equivalent
    By mrcrsr in forum Technical Discussion
    Last Post: 01-13-2008, 10:38 AM
