Results 1 to 7 of 7
    Jan 2010
    Toronto
    Mercury 200 Black Max - Hole in Block - Fixable?
    Cylinder #1
    Hole in wall
    Can this be fixed?
    Jul 2013
    Absolutely.
    Jan 2010
    Toronto
    That's good news ....
    What is the process? Welding / Filling and then machining?
    What type of machine shop am I looking for? General engine shop that does the head machining etc ....
    Or done I need a more specialised shop?
    I see you are in California .... I am in Toronto Ontario CDN.
    If anyone is in southern Ontario that can suggest a name ....I would appreciate it
    Pekin, IL
    Welcome to the site. Really don't need a machine shop just someone that can weld aluminum and owns a grinder.
    Rock
    Team Junk
    Jul 2002
    FT WORTH, TEXAS
    i have fixed several much worse then that its apiece of cake
    Jan 2010
    Toronto
    Again, good news and I found a shop that is fixing it.
    Great help to those that replied
  1. is this 2005 300X block fixable?
    By noli in forum Technical Discussion
    Last Post: 07-19-2015, 01:33 AM
  2. Mercury Tech: 1994 Black Max 200 EFI Hole #2 melt down
    By Hole$hot in forum Technical Discussion
    Last Post: 07-06-2012, 07:12 PM
  3. OMC Tech: Two hole looper coil should show continueity between black wire and metal bracket?
    By audiobill5 in forum Technical Discussion
    Last Post: 09-10-2010, 02:22 PM
  4. Mercury Tech: hole in block
    By johnsinbelton in forum Technical Discussion
    Last Post: 04-22-2009, 06:02 PM
  5. hole in block
    By petros in forum Technical Discussion
    Last Post: 04-02-2004, 04:15 PM
