Results 1 to 11 of 11
    Jun 2012
    Indiana
    21 Superboat porpoising
    I have a 1986 Superboat 21 with a new 300xs. It's on a 10" manual plate. 30 big eared chopper. Boat is porpoising badly. Tried moving motor up and down, which helped the porpoise but it's still there. Also tried a 27 trophy plus and it was worse. Any ideas or advice is greatly appreciated. Click image for larger version.
    First things first get rid of them rollers and put some bunks on it. Put a long straight edge to the bottom and see if its straight any thing beyond that is weight distripution, trim and prop. JMO
  3. Thanks capteliminator thanked for this post
    Likes nitro_rat, Jimboat liked this post
    Jul 2012
    Lufkin, Texas
    Josh Peterson
  5. Likes capteliminator liked this post
    Jun 2012
    Indiana
    Boat is solid and bottom is straight. I fully rebuilt that roller trailer and there are no dips in the bottom were the rollers rest!! Boat had a V8 Evinrude on it when I bought it. It had a 6" plate it and didn't porpoise. Maybe need less setback?
    Dec 2006
    Mt. Laurel, N.J.
    What mph are you running when it starts porpoising? Does it go away at high speeds?
    My 21 had a slightly soft transom which induced porpoise. Replacement cured it completely.
    The roller trailer has to go. It will eventually destroy your hull.
    Azure AZ259, 8.1
  8. Likes capteliminator, OrangeCrush liked this post
    Jun 2012
    Indiana
    Transom dead solid. Porpoise goes away around 45 to 55.under hard throttle it goes away till about 70 then starts again. I checked transom when I changed plates and it's solid. I'm gonna bolt the 6" back on and try again.
    Get a thru hub prop on it and see if the porpoise goes away....Gives a lot more stern lift.
  11. Thanks capteliminator thanked for this post
    Likes KIRCHNER liked this post
  12. #8
    whats your prop height in relation to bottom? How high have you been? I run 1 1/2" above pad
  13. #9
    Aug 2011
    When you're full out how fast will it go and how high is the roost? I think you need more setback or more blade area as it appears to be struggling to hold the bow up. I had the same problem, and went from 6 to 10" of setback, still needed more blade area to help leverage the bow up at slower speeds. Bravo 1 xs with it's 4 blades and 15.25" diameter did the trick.
    1989 21' Skater - twin 2.5s
    1986 Cougar 21MTR, 15" 300XS - sold
    2002 TUFF 21 (#0.1), 300xs - sold
    1986 Valero YT, 225 Promax - sold
    1987 Viper, 140 cross flow - sold
    Jun 2012
    Indiana
    I ran the boat at all heights. I started at 1/2" up, then went down to 1/2" below. Went down more, then tried it all the way up at 1" above no luck. I ran a 300x before with a 12" and a 14" plate and it was better but would porpoise at 65 up. Changed to the opti motor and shortened setback due to 40 lbs heavier. Boat has never carried the bow well with the merc. Ordered a bravo 1 and drug out the original jackate. It's actually a 5". Do any of you guys run a power jackplate? I'd love to keep the boat simple but a power plate seems lime it would really help.
    Yes, on the hyd jackplate. It will spoil you. Leave it low for cruising, run it up for blasting. I have an old land and sea on the stream.
  1. Porpoising
    By mbrien in forum Props, Setup, and Rigging
    Last Post: 03-14-2011, 09:22 AM
  2. Porpoising
    By 2009z in forum Technical Discussion
    Last Post: 11-16-2010, 10:27 PM
  3. Porpoising?
    By NFA Avance 33 in forum Props, Setup, and Rigging
    Last Post: 09-21-2005, 11:08 PM
  4. Porpoising
    By NFA Avance 33 in forum Technical Discussion
    Last Post: 09-09-2005, 11:02 AM
  5. porpoising, why????????
    By northeastcat in forum Technical Discussion
    Last Post: 08-18-2002, 06:43 AM
