Page 7 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 91 to 105 of 167
  1. #91
    I've been hanging the fuel rails and the engine harness by plastic wraps not knowing that all connections were already disconnected from the engine
    Attached Thumbnails Attached Thumbnails 20190119_083755.jpg   20190119_083740.jpg   20190119_083740.jpg   20190119_083755.jpg
  2. #92
    removed the hanging fuel rails and engine harness
    Attached Thumbnails Attached Thumbnails 20190119_084813.jpg   20190119_084813.jpg   20190119_084822.jpg   20190119_084822.jpg
  3. #93
    removed the coils bracket
    Attached Thumbnails Attached Thumbnails 20190119_092338.jpg   20190119_092338.jpg
  4. #94
    I put the engine stand under the hoist and started lifting the hoist to remove the engine block. because of the angle of the hoist opposes the angle of the engine stand, the block was not separating the way I'd like it to
  5. #95
  6. #96
    Attached Thumbnails Attached Thumbnails 20190120_123212.jpg   20190120_123212.jpg
  7. #97
    Attached Thumbnails Attached Thumbnails 20190120_123156.jpg   20190120_123156.jpg
  8. #98
    from the ground looking up at the block
  9. #99
  10. #100
    sorry for the background mess, its gonna go down to 5* F tonite here in NJ, so I have to do all of the work in my garage
    I didn't like the way the block was on an angle as the hoist was pulling up on the block, so I put a jack under the engine stand to lift and thus keep the bolts straight with the hoist
    the block came off like butter, just like the way the flywheel came off....like butter
  11. #101
    Dec 2013
    georgia
    Good job
    So what's next
    Sending to an engine builder
    I found the best way pull studs out block is with vicegrips pliers or pipe wrench
  12. Likes noli liked this post
  13. #102
    Thanks
    Remove the pistons, crankshaft
    Measure the cylinders bore
  14. #103
    Ok will use vice grip or pipe wrench
  15. #104
    Dec 2013
    georgia
    Quote Originally Posted by noli View Post
    #4, no good
    Attachment 426989
    Best way too remove pistons is with front half off one at a time. Please keep rod bolts and cap to its specific connecting rod. Buy some zip lock bag to keep rod bearings and cage together label with sharpie for that cylinder.
    There is really no need to measure cylinder bore at this point unless you plan to buy all new pistons and go size above what you have. If you just want repair #4 The machine shop will give you their recommendations once honing work is done.
    Just looking at #4 you might get away with honing.
  16. #105
    sounds good JZ,
    will do
  1. Mercury 2005 Saltwater Series 200 HP Carburetor Failure
    By Saulunaproline22 in forum Technical Discussion
    Last Post: 07-02-2018, 02:12 PM
  2. 2015 Playcraft Daytona Saltwater Series w/Mercury 250 Pro XS
    By Carlson150XS in forum Hulls larger than 20'
    Last Post: 12-04-2017, 05:36 PM
  3. Replies: 0
    Last Post: 08-04-2014, 10:02 PM
  4. Mercury Tech: Rebuilt 125 hp Mercury Saltwater Series Powerhead Break-In
    By rickyo in forum Technical Discussion
    Last Post: 07-09-2010, 01:54 PM
