Page 6 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 76 to 90 of 167
  1. #76
    May 2014
    Livingston, Louisiana
    It’s some stuff T-Rex was getting/making. I was getting them from him ready to go.
  2. #77
    Dec 2013
    georgia
    Quote Originally Posted by Tango View Post
    Which Opti uses a 3-petal reed cage? Mine all have a 5-petal rubber coated cage with carbon reeds.
    One petal covers two as forbeatuo stated. The standard optimax came with 6 petal cages and the optimax xs/pro xs was 5 petal cages.
  3. Thanks Tango thanked for this post
  4. #78
    Florence, SC
    I was looking at the attachment and do you have to drill the cages?
  5. #79
    I don't think the cages need to be drilled
    I took JZ's image and I aligned the screws of CCM's 3-petal fibre reeds on top of Mercury's 6-petal reeds and they seem to align pretty good
    on these special CCM 3-petal reeds, the 1-petal-large-reed covers 2-ports
  6. #80
    continuing with engine dismantle
    Port side
    Before
    After
    Attached Thumbnails Attached Thumbnails port_full.jpg   port_full.jpg   port_empty.jpg   port_empty.jpg
  7. #81
    Stbd side
    Before
    After
  8. Likes tux974 liked this post
  9. #82
    flywheel puller came in
  10. #83
  11. #84
    Dec 2013
    georgia
    Spray some liquid penetrating Lube and loosen bolt enough to be flushed with threads on crankshaft to protect threads.
    Noli will you be pulling rods and pistons out yourself to do rebuild or you sending to a shop for rebuild
  12. #85
    Hi JZ
    Thanks for the info, Please feel free to drop any valuable info like the one you just posted
    I will be pulling the Internals then block will be bored and honed
  13. #86
    JZ!
    thanks brother!
    the flywheel came off with slight issue. Yesterday I was wrestling with the thing, did not want to budge, so I kept soaking it with WD40
    This morning I simply lifted it off the crank!
    I actually used a $14 automobile harmonic balancer puller from Harbor Freight cause I was afraid to strip the threads on the flywheel
    Before pic, with the alternator, pump, flywheel still on
  14. #87
    After, the blank top
  15. #88
    Dec 2013
    georgia
    Quote Originally Posted by noli View Post
    JZ!
    thanks brother!
    Nothing a nice block of 2x4 and hammer couldn't fix with couple taps to the flywheel. Don't use harmonic balancer puller it's not enough meat on crankshaft center to put force on it could split crankshaft head.
  16. #89
    Oh man I'm gonna look at the crankshaft to be sure I didn't damage it
    But actually by the time I used that puller, the wd40 has already done it's magic overnight and the flywheel came off like butter
  17. #90
  1. Mercury 2005 Saltwater Series 200 HP Carburetor Failure
    By Saulunaproline22 in forum Technical Discussion
    Last Post: 07-02-2018, 02:12 PM
  2. 2015 Playcraft Daytona Saltwater Series w/Mercury 250 Pro XS
    By Carlson150XS in forum Hulls larger than 20'
    Last Post: 12-04-2017, 05:36 PM
  3. Replies: 0
    Last Post: 08-04-2014, 10:02 PM
  4. Mercury Tech: Rebuilt 125 hp Mercury Saltwater Series Powerhead Break-In
    By rickyo in forum Technical Discussion
    Last Post: 07-09-2010, 01:54 PM
