Page 11 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 151 to 165 of 167
  1. #151
    you have sharp eyes
  2. #152
    the following measurements are overages to the standard size bore 3.625 inches in diameter
    I used a dial bore gauge to make these measurements prior to sending them out to Fuller's Marine
    how_to
    each cylinder has 2 measures that says "top" measurements for each cylinder. These were measured 90* apart. Same as the "bottom" measurements
    it would have been better if I drew the measurements below in 3-D, but you can figure it out
    Because Cyl 4 had a cooked piston, George Fuller of Fuller's Marine bored and honed all 6 cylinders to 0.015 measure to fit the 0.015 rebuild kit
    as you can see from the measurements of cylinder #4, I just barely made it to the 0.015 rebuild kit. sure glad the previous owner didn't force the extended running of the failed motor
    btw, George Fuller did a marvelous job with the block as well as my air injectors cleaning, posts to follow
    there are only a handful of very good machinists around the country, Fuller's Marine is one of them. we have to support them so that we can continue with our 2-stroke boating passion
  3. #153
    engine parts inside labeled boxes for a 5 month slumber
    'cause the garage will get very dusty with fiberglass work
  4. #154
    its a short season for warm temps in the north
  5. #155
    got my service manual hardcopy for older 225 EFI's but still very useable and I also have a digital version but for my year (2005) motor
  6. #156
    just a short clip from my digital service manual (PDF format)
    so that's how the water flows
  7. #157
    anybody know what #14 is saying?
    "14 - Block Water Pressure Sensor"
  8. #158
    I've got everything else apart, I'll just remove the adapter plate
    looking down the housing
  9. #159
    Dec 2013
    georgia
    Quote Originally Posted by noli View Post
ID:	455787Click image for larger version.
  10. Likes noli liked this post
  11. #160
  12. #161
  13. #162
  14. #163
    Happy New Year 2JZ,
    from the diagram, #14 is pointing to the nose cone, that's what got me confused
  15. #164
    Nov 2019
    Canada
    Noli, it looks like there is a typo in the service manual. "14" and "15" on the lower unit in the circle should be labeled "15" and "16"
    www.InjectorService.com
    Call/Text - 204-326-0390
  16. Likes noli liked this post
  17. #165
    Injector,
    You're gooood!
    Could never have figured that out
  1. Mercury 2005 Saltwater Series 200 HP Carburetor Failure
    By Saulunaproline22 in forum Technical Discussion
    Last Post: 07-02-2018, 02:12 PM
  2. 2015 Playcraft Daytona Saltwater Series w/Mercury 250 Pro XS
    By Carlson150XS in forum Hulls larger than 20'
    Last Post: 12-04-2017, 05:36 PM
  3. Replies: 0
    Last Post: 08-04-2014, 10:02 PM
  4. Mercury Tech: Rebuilt 125 hp Mercury Saltwater Series Powerhead Break-In
    By rickyo in forum Technical Discussion
    Last Post: 07-09-2010, 01:54 PM
