Page 10 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 136 to 150 of 167
  1. #136
    ---> https://www.facebook.com/MillerRacePhotos/
    Bore Gauge....check
    favorite DW32 Raceboat paint job.....check
  2. #137
    Measuring thingy....check
    favorite DW 32 Raceboat paint job......check [again]
  3. #138
  4. #139
  5. #140
    Exhaust plate
  6. #141
    Now is the time to install solid mounts if your mounts are soft. ProMarine sells them.
    Also those rubber drain tubes behind the mid bolts have a little ball as a check valve in them, good time to clean so they drain well.
    Plate surface very light sanding and spray lightly with heat paint.
  7. #142
    Thank you Tony, Please add as much info as you can in this thread. Will clean the ball-valve and apply heat paint on plate surface.
    The solid mounts are on the 20" mid that I purchased from 2jz (great seller) --> https://www.screamandfly.com/showthr...73#post3065273
  8. Likes tux974 liked this post
  9. #143
    Midsection time!
    Removing the mid can
  10. #144
  11. #145
    Removed the 25" can
  12. #146
    Comparing the two cans 20" vs. 25"
    side-by-side
  13. #147
  14. #148
  15. #149
    My new-to-me 20" can
  16. Likes tux974 liked this post
  17. #150
    Coming along. I see you will need to drill out that broken lower mount plastic cover screw ... Very common to get out without breaking most times.
  1. Mercury 2005 Saltwater Series 200 HP Carburetor Failure
    By Saulunaproline22 in forum Technical Discussion
    Last Post: 07-02-2018, 02:12 PM
  2. 2015 Playcraft Daytona Saltwater Series w/Mercury 250 Pro XS
    By Carlson150XS in forum Hulls larger than 20'
    Last Post: 12-04-2017, 05:36 PM
  3. Replies: 0
    Last Post: 08-04-2014, 10:02 PM
  4. Mercury Tech: Rebuilt 125 hp Mercury Saltwater Series Powerhead Break-In
    By rickyo in forum Technical Discussion
    Last Post: 07-09-2010, 01:54 PM
