Results 1 to 10 of 10
Thread: 96 225 Carbed issue
07-14-2018, 07:22 AM #1Member
- Feb 2018
- S. W. Georgia
- 86
- 10
- 7
- 945
- 56
96 225 Carbed issue
Got a 96 225 carburetor mercury. After a long run, when I idled down it was skipping and had little power. Finally got it back up on plane, no skip and run fine. Got home and put muffs on it. It is huffing out the number 4 carburetor. What could be the problem. Compression runs 105-110 on all cylinders. Thanks.
07-14-2018, 08:46 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Reeds.....
07-15-2018, 01:32 PM #3
Could had sucked up some trash maybe? Clean carbs and take a peek at reeds with flash lite while carbs are being serviced
07-15-2018, 01:37 PM #4
07-16-2018, 06:34 AM #5Member
- Feb 2018
- S. W. Georgia
- 86
- 10
- 7
- 945
- 56
Thanks
07-16-2018, 08:49 PM #6Member
- Feb 2018
- S. W. Georgia
- 86
- 10
- 7
- 945
- 56
07-16-2018, 10:50 PM #7
It depends.......
Pull the heads and post pics of you really want to know.Azure AZ259, 8.1
07-17-2018, 04:35 AM #8
the bad set of reeds look rusty.
07-17-2018, 06:48 AM #9
07-18-2018, 07:38 AM #10Member
- Feb 2018
- S. W. Georgia
- 86
- 10
- 7
- 945
- 56
Scoped it last night. No sign of the reed. Top of piston looks fine. Maybe it spit it on out.
2.5 200 Carbed
By Radazzle in forum Outboard EnginesReplies: 1Last Post: 05-20-2018, 02:10 PM -
Mercury Tech: Dual temp gauges issue OR engine Issue
By dompie99 in forum Technical DiscussionReplies: 4Last Post: 05-24-2016, 09:37 AM -
250xs top cowl melting common issue or is there an internal issue I should look for
By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 08-30-2015, 05:14 PM -
Carbed 260
By Reddawgzulu in forum Technical DiscussionReplies: 15Last Post: 04-24-2007, 05:15 PM
