Results 1 to 3 of 3
Thread: Removal of steering arm
07-11-2018, 04:55 AM #1Member
- Feb 2018
- SA
- 52
- 9
on a Johnson 2.6lt 235hp can i remove the steering arm without removing the powerhead ,by removing the upper and lower mounting bolts ,the tilt tube and the lower unit is that possible any help appreciated ,thanks very much
07-11-2018, 11:46 AM #2
Yes... pull the lower unit, put on a lift ring, pick up the weight of the engine with an engine hoist, remove the 2 upper and 4 lower foreward facing mount bolts then swing the eng out of the way, pull the lower mount shoe off the bottom of the tiller and it will slide right out..
07-12-2018, 02:45 AM #3Member
- Feb 2018
- SA
- 52
- 9
H20PERF thankyou for the reply ,sure is going to save me a lot of labour
Morse steering removal
By bahnerboater in forum Technical DiscussionReplies: 0Last Post: 07-22-2016, 12:06 AM -
Johnson 225 factory power steering- removal
By Captain75 in forum Technical DiscussionReplies: 5Last Post: 11-02-2012, 04:35 PM -
OMC Tech: 225 power steering removal
By catfishjn69 in forum Technical DiscussionReplies: 0Last Post: 10-20-2009, 09:54 PM -
Steering removal
By Restream in forum Technical DiscussionReplies: 1Last Post: 05-24-2005, 08:51 AM -
Steering Cable Removal
By Karl817 in forum Technical DiscussionReplies: 14Last Post: 06-01-2003, 11:26 PM
