Results 1 to 5 of 5
Thread: leaks
07-09-2018, 01:25 PM #15000 RPM
- Nov 2001
- ft. wayne,In
- 692
- 16
- 7
- 52
- 9
leaks
Have a 1988 hydrostream vegas. got into some rocks and damaged the verey rear of the pad. Glass is showing and water is leaking through the damaged area. Entire damaged area is less than 2 square inches.
Any good ideas on how to fix it,at least well enough toi get me through the summer?
Any advice is much appreciated.
07-09-2018, 01:53 PM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
*warning* If you are running fast there is a lot of pressure on that area. Could cause de-lamination and disaster. I would skip the fast fix and have it done right. That said, some marine tex would fill the hole for now. Grind/sand it clean and let it dry. Apply some epoxy putty for a quick repair.
rock liked this post
07-09-2018, 02:31 PM #3
Any pictures? With the outside hull damaged, there should not be any water getting into the hull that needs to be drained, if there is you have more damage than just the outside glass, you damaged core and the inner fiberglass under the floor as well and will need some more though put into the repair. Not rocket science but you will be more involved as you will have to remove core and replace in that area. And when you get in there and it is still the original core, you know what comes next.....
1973 Viper - sold
1978 Viking - sold
1995 XB02
David - WI liked this post
07-14-2018, 12:01 PM #47000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
x is right on. i have many marine tex patches in my voyager. some over 15 yrs old. i use the clear packing tape the hols the putty in place and give a smooth surface.
07-14-2018, 02:16 PM #5
Belzona 1111
Belzona makes a lot of almost unbelievable epoxies and related patch repair/coating products. Steam industry uses their products. Not sure if anyone uses it for hull repair aside from the big ships but it is probably a lifetime type patch for those who dont need to dig deeper. I've never used it submersed but I have used JB weld in some engine applications and it held up extremely well. I wonder if its suitable?Hydrostream dreamin
mirage leaks?
By lajons in forum Technical DiscussionReplies: 5Last Post: 10-16-2009, 06:51 PM -
I have some leaks....
By cocacola in forum General Boating DiscussionReplies: 3Last Post: 05-21-2007, 07:20 PM -
How to fix leaks in jet boat?
By ak.hunter in forum Jet Boats, V-Drives and Stern DrivesReplies: 8Last Post: 03-25-2007, 10:34 AM -
STV rubrail leaks
By nelsoncat in forum Technical DiscussionReplies: 4Last Post: 09-20-2005, 08:11 PM -
the end of my pipe leaks!!
By Talon2.5 in forum General Boating DiscussionReplies: 19Last Post: 08-31-2002, 07:44 PM
