Results 1 to 15 of 22
Thread: ETEC 225 failure
07-03-2018, 12:27 PM #1
ETEC 225 failure
Well a very sad Canada day weekend for me as my V-6 is now a V-5. I havent had a chance to get the heads off yet but upon removal of the spark plugs i can see that the port side top cylinder is in pieces. So my main question here is as I disassemble, what kinds of things should I be looking for? ie: common failure points. I have read a few threads here and there of air bubbles in the oil system after a re-rig that caused failure of upper cylinders. I did just re-install the powerhead so that would make sense, but what are the signs of this or is it even true? I would assume that by priming the bulb that the system is primed and G2G. if its injector failure what would signify this? im just at a loss here, its been such a strong motor for me and now this. potentially a season ruined.
Part B of all of this is now that im doing a rebuild, is it possible/ what would it take to make this into a 250HO? Engine is currently a 2005 225HO. can the powerhead be made into a 250HO or are the differences to great????
any input appreciated guys, Thanks.
07-04-2018, 01:19 AM #2
07-04-2018, 02:17 AM #3
Looks fired leaned right out just in the one so maybe injector failed? Im NO expert at all in this but thats what it looks like to me. Got hot melted the top and blew the rod right threw the melted piston top from not getting oil and or fuel.
07-04-2018, 02:21 AM #4
You may get lucky and need to work just that one bore and new piston correct and flow fuel rail or reed failure? As you go deeper it will become more obvious what it was. Take lots of pics the OMC boys will know what caused this. Good luck man i hope you can have a speedy recovery and get august and sept in before you know what! haha
07-04-2018, 10:27 AM #55000 RPM
- Aug 2002
- florida
- 804
- 13
Injector failed. You probably felt it start to lay down.
07-04-2018, 05:33 PM #6
that's pretty much how it felt before she started knocking on failures door. god damn two strokes
07-07-2018, 02:02 AM #7Member
- Feb 2017
- Naples FL
- 74
- 27
- 9
I'm constantly worrying about this with my Yamaha HPDI. If it's not performing 100% it doesn't get used until I find the problem. I love the fuel economy, but I hate all the high pressure crap.
07-07-2018, 09:11 AM #8Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
When rerigged the oil system needs to be bleed and primed. Before full disassembly IMO get a print out off the computer as it may give ideas as to why. After reassembly oil needs to be verified and I personally would replace the injector. No you can not make yours into a 250HO as they have a longer stroke crank, different style injectors etc.
07-09-2018, 02:18 PM #9
07-09-2018, 02:48 PM #10
ouch
07-09-2018, 03:29 PM #11
07-09-2018, 07:25 PM #12
07-09-2018, 07:27 PM #13
If anyone was currious first quote is in and $8500 CAD for a new powerhead. there has to be cheaper options.... i didnt even pay that for the complete motor w/ controls.
07-09-2018, 07:54 PM #14
derpid thanked for this post
07-09-2018, 09:09 PM #15
Why are ETec G2 H.O. Motors selling for less than the older Etec H.O.'s ?
By Pachanga_rick in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 48Last Post: 03-05-2016, 01:51 AM -
ETEC Diagnostic Kit - Want to order. Fault with motor not reving Etec 75Hp
By riverrat321 in forum Technical DiscussionReplies: 4Last Post: 01-29-2016, 07:19 AM -
Difference between 2008 etec 200ho & 2011 etec 200ho??
By coojac in forum Racer's HangoutReplies: 2Last Post: 09-02-2013, 05:43 PM -
Etec 250HO vs Etec 300
By fasttoons in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 4Last Post: 01-18-2011, 10:28 PM
